IR3300i *2&8* no responding? IR3570 firmware needed
  • btobject
    • Jun 2010
    • 9
    Hi,
    Is there a way to work around this *2&8* to enter the service mode? I tried so many times, but just could not get into it to check the firmware version.
    Also, I need the latest IR3570 firmware. May someone please help me? Thank you very much.
  • kuby
    • Oct 2007
    • 1373
    Try *1&7* , some models had it where you could set it for two different access codes.
    • teckat
      • 16083
      Originally posted by btobject
      Hi,
      Make sure u are using correct *asterisk key/ shown below red line in pick/click on pic/
      also check for a stuck or broken key(button)- many hit the star key by mistake
      • ahmad
        • Jun 2010
        • 28
        hi you can first check the astrisk key and tryh to clean it and i have the sys. software for the ir3570
        • teckat
          • 16083
          you may have it/ but it's no good if poster has no knowledge of SST
          • ahmad
            • Jun 2010
            • 28
            ir3570
            if you want hdd with sys. 3570 on it i can get you
            • teckat
              • 16083
              if it's not >>
              it's worth nothing
              • SCREWTAPE
                East Coast Imaging
                • 3396
                What version is on the HDD?
                • teckat
                  • 16083
                  Hi,
                  u can try *4 & 9 * to get in.
                  if you can get in _hit the *2 key to enter Level 2
                  then go to COPIER>OPTION>BODY _ SVMD-ENT in there you will see if someone switched it >
                  change it back if u want/ select either 0 or 1 setting
                  SVMD-ENT = Setting Values 0:= [2] and [8]
                  1:= [4] and [9]
                  good luck
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    1:= [4] and [9]
                    good luck
                    I actually posted this before but I deleted it.
                    I don't think the 3300i has this feature.
                    Didn't it start with the 70 series.
                    • teckat
                      • 16083
                      could be right/ have to check if firmware ever addressed it/ will report back
                      • kuby
                        • Oct 2007
                        • 1373
                        Could not remember if this one had that feature either. And could not remember if ti ws 1&7 or 4&9. The only time I ever try and access it is when the 2&8 does not work because someone changed it tying to prevent a end user from gaining access.
                        • btobject
                          • Jun 2010
                          • 9
                          Thank you very much for all of you kindly support. I am facing two copiers, IR3300, and IR3300i, refusing *2&8* to the service mode. *1&7* and *4&9*, tried with no luck. I will replace ROMs and HDDs for these two to see if they comply.
                          • SCREWTAPE
                            East Coast Imaging
                            • 3396
                            You must try harder.
                            As you try hitting the keys, and if it does not respond, hit the reset button and try again.
                            Forget about 1&7 & 4&9.
                            • teckat
                              • 16083
                              forget about service mode
                              for now
                              try this > forget about *asterisk key for now / turn off main switch> hold down the 1 and 7 key> keep holding both numbers>turn on main switch,while still holding them down> do not let go until u see the main screen and a FIX -IP in top corner of control panel/ then
                              in
                              common settings>Report Settings> print out a User Data List> check
                              if your iR3300 System Software and Language Versions match up/ it can cause control panel issues
                              try and get in service mode now- if u can>COPIER>FUNCTION>SYSTEM>DOWNLOAD and push [OK].
                              Hook up n' Start up SST and re-load 3300i Firmware ALL
                              After downloading, the main power switch must be turned OFF/ON and then
                              the main body must be re-booted. The system software saved in the temporary storage space of the HDD is written in the system area and the flash ROM. The
                              machine starts with the downloaded system software by turning OFF/ON the main power switch.
