Hi
I'm upgrading an old Xerox with a Canon iR Advanced C5051. The Xerox had a EFI Fiery attached, and one of the features that the users made use of on the Fiery is the scan to mailbox facility. The feature functioned as follows: (1) the user would scan the document to a mailbox on the Fiery's Hard Drive. (2) the file would then be downloaded from the mailbox using the Fiery Remote Scan utility.
I have the Canon setup to scan in the same way as the Xerox, but the problem is, on the Xerox there is a very nice shortcut that has all the necessary settings saved, such as scan in colour, scan from ADF, 300 dpi, save as PDF, including the mailbox name on the Fiery where the scan should be stored, but on the Canon i can't figure out how to register a shortcut like this. Every time a user wants to scan, all of the beforementioned settings have to be manually configured. This is of course a huge problem for the users and I dont blame them... there is a hell of a lot to config before starting your scan.
Does anybody have any ideas on how i can improve this situation, or register a similar shortcut on the Canon
Thanks in advance for any help
