How To use SST
  • dipo_alam
    • Sep 2025
    How To use SST
    Hi all
    This is my second post about canon copier Problem.
    I have SST software SST Ver 335 (If i am not mistaken), but i dont know how to use the software. How to use it and what hardware do i need when using this software?.
    Can i get step by step instructions ?
    I also want to asked about Canon IR4570, I just buy one canon IR4570, but the machine dont have Fax. Does anyone know Fax partnumber for this machine? do i just need the fax board or any other part if i want to use fax (other part such as speaker so i can hear dialing tone)? My machine is 220Volt, can i use fax board from 110Volt machine?
    Thank you all for your help.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    SST is used to install firmware. You need firmware, and the hardware would be a laptop and copier.
    Not to sure about the fax ??? but the 4570 is discontinued, so finding one fax board might be a little challenging.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Super G3 Fax Board-Q1 9568A002AA
      This is what you are looking for, you might try e-bay or Google for it. The kit contained the fax unit, speaker, and some harness wiring.
      • dipo_alam
        Thanks guys for all your helps
        • mrfixit51
          • Oct 2008
          • 1975
          You are welcome...
          • SCREWTAPE
            East Coast Imaging
            • 3396
            No problem.
