Canon ir8070 - 240v help
  • kuby
    • Oct 2007
    • 1409
    Will this machine work on a 240v circuit? I know the manual says 188v to 228v 12A or more. The only plug in the building is 240-245v. I don't want to fry the boards or anything.
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Even if it would work on that circuit which I doubt - Your best bet would be to have the customer call an electrician & pay to have him setup an outlet with the voltage you need. As a rule of thumb - Never play around with power requirements . Play it safe my friend.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      That's the best advice.
      • kuby
        • Oct 2007
        • 1409
        Thanks Guys
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Forget about performance and poofed boards - I would think if the copier were to ever start a fire, God forbid, that your dealership could be held liable if the customer could prove that you knew of the high voltage, and allowed it anyway.
          It would be better to lose the business than to assume the risk.
          • teckat
            • 16083
            Originally posted by kuby
            will this machine work on a 240v circuit? I know the manual says 188v to 228v 12a or more. The only plug in the building is 240-245v. I don't want to fry the boards or anything.
            This link below has all CANON Power requirements for their Machines
            http://docs.google.com/viewer?a=v&q=...2MBhTPSf9_c6qw
            click on pics
            dedicated 208vac
            15 amp max
