HP 4600 printer
  • Atta
    • Jul 2010
    • 26
    HP 4600 printer
    I have HP4600 color printer which doesn't print color but print none color document. it will not print the document if there is a letter with a color font. what could be the problem.
    help me out guys.
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    You posted this in the wrong forum (Canon).
    If you post in the HP forum, you should get better results.
    • teckat
      • 16083
      help me out guys.
      Wrong Forum for HP/
      go to HP Support site for your product HP4600 , LINK IS BELOW
      http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom〈=en&h_ client=S-A-R163-1&h_query=HP4600&submit.x=0&submit.y=0
      • JustManuals
        • Jan 2006
        • 9838
        Is there toner in ALL the cartridges?
        • Atta
          • Jul 2010
          • 26
          Yes and i even replaced all with new toner's
            • 23009
            Atta,
            I am still a little unclear about the symptoms.
            Are you saying that color prints come out as blank, color prints come out as monochrome (black & white), or color prints have some other quality defect.
            Can you post a scan of the quality problem. It's helps a lot to see the problem. =^..^=
            • djandl
              Colorado Copier Solutions
              • May 2010
              • 19
              If I was a betting man, and I am, it sounds like a permission was setup to limit color printing and if there is one character of color, the printer does not allow printing. Normally you can check the setup of the printer by going to the Web Page through the IP address and see if some permissions were set up via the color permissions area. Basically everytime anyone sends a color print job through the printer driver, the user name and job name (web page name, Word document, etc) and the printer recognizes it, due to the fact this information is stored in the header. If you check and these option is not programmed. I would check the menus for a printer color lock out mode. I am not that familiar with HP, but many other manufacturers' use this mode to help limit color.
              http://coloradocopiersolutions.com
              info@coloradocopiersolutions.com
              • Atta
                • Jul 2010
                • 26
                Sorry if you didn't get me well, It's a color printer and it doesn't nay color job sent to it, When you have full page of words and if a letter just one letter in the content of the document the printer will never print the document at all. but it can print any none color document. Hope you get me this time a round. Thanks
                • teckat
                  • 16083
                  this is a Canon Forum/ post in correct Forum/ HP has a great site for support, i posted the link for you
                  HP 4600_Print Quality Troubleshooting Tool
                  Setup color procedure using Microsoft Internet Explorer
                  this link will hopefully fix your issue , follow instructions, click on link above
                  Also
                  Print your Configuration Page
                  1. Press to enter the MENUS on the control panel of the printer.
                  2. Press to highlight INFORMATION.
                  3. Press to select INFORMATION.
                  4. Press to highlight PRINT CONFIGURATION.
                  5. Press to select CONFIGURATION.
                  The message PRINTING... CONFIGURATION appears on the display until the printer finishes printing the Configuration page. The printer returns to the Ready state after printing the Configuration page.
                  *The Configuration page is used to view current printer settings, to help troubleshoot printer problems, or to verify installation of optional accessories, such as memory (DIMMs), paper trays, and printer languages.
                  instructions on link below>
                  /http://h10039.www1.hp.com/cpso-support-new/pq
                  /4600/configuration.html
                  they also have free support
                  HP Instant Support Professional Edition
                  http://h50203.www5.hp.com/hpisweb/customer/HPInstantsupport.aspx?&cc=us〈=en
                  HP Instant Support Professional Edition provides web-based support tools that automate and speed the resolution of technical problems on HP products.
                  English Language Support per Product Group
                  Server
                  Available Worldwide, 24 x 7 on all supported Servers products.
                  Storage
                  Asia Pacific, Japan, Europe, Middle-East and Africa, available 24 x 7 on all supported Storage products.
                  Imaging & Printing
                  Available Worldwide, 24 x 7 on all supported Imaging & Printing products.
                  Computing
                  Americas & Asia Pacific, available 24 x 7 on all supported Computing products.
                  Europe, Middle-East and Africa, available 9am - 3am CET (Central European Time).
                  All other supported languages
                  Hours of operation will vary to conform to local standard hours of business support
                  • teckat
                    • 16083
                    add on info> Make sure you have the correct Print Driver installed
                    Network Defects
                    As a known defect in the networking card, this is the only problem the HP 4600 has that won't cost you a penny to fix. Occasionally the networking card, JetDirect, will fail. Meaning, you can no longer print from your computer. HP is well aware of this defect, and will fix it free of charge.
                    ****Printing black instead of color
                    Cause
                    Color mode is not selected in the software
                    application or printer driver.
                    Select color mode instead of grayscale or
                    monochrome mode in the software application
                    or printer driver.
                    Cause
                    The correct printer driver is not selected in
                    your software application.
                    Select the correct printer driver.
                    or you may have a Defective HP print cartridge Replace the cartridge.
                    A non-HP cartridge might be installed.
                    Ensure that you are using a genuine HP print
                    cartridge.
