IR3300 ip setting
  • mfcm
    • Aug 2025
    IR3300 ip setting
    Hi guys,im sorry if theres oalready same post like mine
    i got 1 unit ir3300 at my working place that i need to connect to pc for direct printing,
    but the problem is,ive already set the ip 10.173.205.250 for the machine while my pc 10.173.205.206..im connecting those 2 units via switch..but when i ping between those units i cant reach it..been changed the cable also same..so i tried use another laptop to ping my current pc then the connection established.
    so i wonder why i cant ping the machine..ive tried also using cross cable but still failed :cry:
    izzit because i need to set using admin account for the ip?any step to setting ip i can follow?really appreciate your help..thx
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    There is a 60 second delay for ethernet traffic on those. Are you waiting more than 60 seconds before trying to ping?
    In additional functions-> system settings-> network settings-> TCP/IP-> Ping command, try pinging 10.173.205.250. If you get no reply (after the 60 second delay) then there is an issue with the copier. Once you get a reply from that try pinging the PC. If it still doesn't work lock in the LAN speed. page down while in network settings screen to find the ethernet driver settings. Turn off auto and try 100 half duplex to be safe.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Something else to keep in mind, is that the copier needs to be turned off with the main power switch on the right side of the copier after any network changes are made to it. It is not like XP and makes changes on the fly. A cold start is needed to establish the IP on the network card, and then you need to wait a minute or two for the network connection to come ready as D_L_P mentioned.. Only other possibility I can think of is if the subnets do not match.
      • mfcm
        @D_L_P & mrfixit
        thx alot for the tips..ive tried according the tips given and im happy its work thx alot
        • D_L_P
          Self Employed
          • Oct 2009
          • 1196
          Glad to hear it's working!
          • mrfixit51
            • Oct 2008
            • 1975
            Originally posted by mfcm
            @D_L_P & mrfixit
            Were here to help when we can. Team players get it done!!!
            • mfcm
              guys;
              i just wonder why some of the laptops will popup dialogue window askin for user id and password after i hit the printing button?got any solution?im using same driver for those laptop..but some of them didnt popup the dialogue window..they can print directly..but some of them stuck there..dont know what id and password i need to put
              btw i just found we can "on" to allow printer job for unknown id..will it gv any affect to current setting which all the staff hv given unique ID and password that can allow them to use the printer..if i turn it "ON" mean all the staff can use the printer w/o any password and id?mean anybody can use it w/o limit?
              • mrfixit51
                • Oct 2008
                • 1975
                guys;
                Turn off job accounting on the devices that request user id/password. I believe it is on the Device Settings tab,, the same tab that you find Get Device Status button on it...
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Job accounting its is.
                  • mfcm
                    you guys mean the job accounting located in the laptop or the printer?
                    will there any issue coz all the staff in my work place jus given for 500 copies per id..if i turn it off will it be affecting the limited copies per id?
                    if in the printer its alreadi in "ON" position to allow unknown id..ive wonder coz some of the laptop didnt popup the deparmnt id and password..but some of them the popup appear askin for id and password :-s
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      The issue is on the pc side of the equation, not the copier side. If you are limiting copies per ID, why not limit the prints? The id/password window is brought up on units that have the driver set up to use job accounting. If you are attempting to limit who makes what on the copier, you should require the same of them with printing. You use the same credentials to allow printing as you do to make copies. If no password is required to log onto the copier to make copies, leave that field blank on the popup window for print jobs.
                      • mfcm
                        erm izzit mean i cant to bypass the department id/password in window?i just wonder why some of the laptop doesnt need the deparmtent id/password to print but some of the been asked for it even those laptop using same driver printer..
                        • mfcm
                          Re: IR3300 ip setting
                          hi,sorry need again opinion from all you..
                          the situation like below..
                          1.my working area using static ip for internet connection
                          2.so the copier also connected to the internet line using switch which source from nearest wireless router
                          3.the prob now i cant get reply when ping between any pc on the same line to to the copier..also from copier to other static ip cant get reply.
                          4.when i try to set back the copier ip address.save and turn off the main power for few minutes,i check back the ip not as what i key in..its show 192.168.0.xxx.not same as my working static ip 10.xxx.xxx.xxx..the dns alsno changed.
                          so any solution that i could do?owh yeah the pc that connected to the same switch as the copier can use internet.. tq for your reply
