canon ir3300 warmup problem
  • rais_a1
    • Aug 2025
    1. my canon ir3300 machines is responding late to every function and it is taking time to warm up.
    2. can i myself upgrade the software of machnie.
  • kuby
    • Oct 2007
    • 1409
    You would need the SST and the system software to upgrade. Also probably need a hard drive, from what you said it sounds like it is getting slow and maybe ready to die on you.
    • teckat
      • 16083
      get someone to update the Firmware on printer/ if u never did it before
      • mujibur
        • 53
        your hard disc format re program
        • cableties
          • 35
          Using SST still the better solution
          • teckat
            • 16083
            u need the SST & Firmware before a Format of HD/ on imageRunner
            u should have posted that info
            • blazebusiness
              SanDiegoCopierRepair.com
              • 1257
              You might be able to get away with a hard drive clear...you might just have corrupt data on the drive. I would certainly try that before using the SST. After doing the HD CLR you will need to reinstall all user settings so make sure you print out all the units data sheets before you do anything. If you want more info on how to do the procedure let me know and I can post more info .
              • rais_a1
                warm up problem
                hi,
                i have already tried everything. we have very much service problem here. i have to wait for 2 months if i would call service engineer. and also here are very disturbances now a days.
                so can you kindly please send me system software for ir3300. i shall be very thankful to you.
                please help
                my email address is awonservices@yahoo.com
                • rais_a1
                  hi
                  now i got error code e602-0002 error
                  i cannot connect my pc to machine through parallel cable
                  • blazebusiness
                    • 1257
                    hi
                    Kuby's post in July correctly advised you that your hard drive sounds like it is slowing down and getting ready to die on you. You'll need a new hard drive now and will have to use the service support tool to reload the system software. Probably time to call a Canon rep and get this problem solved for good.
                    If you wanted to attempt this yourself there are a ton of posts on this site that will give you an idea what's involved but -
                    you need to download the system software for the machine or version you need. unpack it and register it with sst . You'll need the correct cable, its not a simple thing to use. Even after reading the service support tool manual it still can be complicated until you learn how to actually do it.
                    Call a Canon guy and be done with it.
