iRC3380i install new drum units
  • Alan Aya
    Dear Fellows Tech,
    Need some advice on changing new drum for iRC3380i. After i replaced the new drum units, what are the steps/procedure i need to do? Please advice.
    Thank you
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    You asked what do you do after you replace the drum -Not much -The machine should detect the new drum unit when you close the front door or turn on main power and blows its fuse. Then it resets drum counter to zero.
    Important that you know how to open up the unit to replace the drums. The factory service manual on page 2-4 details dissassembly and install procedure. Make sure you review that before installing drums.
    I personally like to turn off power before I replace a drum and turn on copier after the install is complete. Hope this helps.
    Also see the following posts & read comments by Mrfixit & teckat
    http://www.copytechnet.com/forums/ca...cartridge.html
    http://www.copytechnet.com/forums/ca...m-irc2880.html
    Probably the most helpful thing is ------Go see that youtube video!!!!!!
    Its Great!
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Nice preview blaze.
      Even a user can change a drum.
      • blazebusiness
        • 1250
        thanks!
        • OoIANoO
          after installing new drums on irc2880 series
          Originally posted by Alan Aya
          Dear Fellows Tech,
          Thank you
          Dont forget to do 'Auto Gradation' after new drums fitted. you should do it 1st with 'pascal' off and the repeat when 'pascal' is back on.
