Part # for attachment sensor arm for puncher unit AH1
  • ReproKev
    • 273
    I have a puncher unit AH1 mounted on a W1 Fin on a c5180. The cust broke off the attachment sensor arm that tells when the finisher is attached to the copier. A wedge of paper works for now but I can't find a good part #.
    I looked in the AH1 (couldn't find it) and W1 parts manuals and ordered #4A3-4180 from the W1 book but that wasn't it.
  • ReproKev
    • 273
    I still can't locate the sensor arm in the AH1 parts book. Anyone have a good part # by chance? Thanks.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      I tried but couldn't find it my self, I wasn't to sure.
      If you could find out what PI sensor that is, it would probably help.
      • ReproKev
        • 273
        The only thing I could find was the joint sensor (PI22) on the finisher W1. I had already ordered the flag for it but it wasn't the same.
        In the Puncher AH1 parts book there is a "joint sensor cable" (under attachment parts) that looks like an entension cable - possibly to move the original joint sensor from the fin to the puncher?
        Anyone have an installation manual from a puncher unit AH1? The answer may be in there.
        • teckat
          • 16083
          I believe that part is attached to [6] Latch Unit (Component on the finisher side)circled in RED BELOW/ double click on pic
          DOUBLE CLICK ON PIC ABOVE
          that unit comes in puncher kit/ still looking for part #
          here u go below>>>>>>>
          The part number to the upper latch cover is 4F3-0930-000. The part number to the lower latch cover is 4A3-4188-000 lower latch cover. The covers are shown in the Puncher Unit AH1 in the image below but there are no part numbers listed.
          the part numbers to the latch covers on the Punch Unit AH1
          Answer :
          • ReproKev
            • 273
            Thanks for finding that! It's on order now, hopefully the flag will come attached to it. I'll post back to let you know.
            • teckat
              • 16083
              If you are talking about that black push button on Puncher it should be on that Puncher Latch Unit Upper Cover/ that is what strikes the Flag Latch Sensor Flag on Finisher W1 Frame.
              if also needed
              u can try this - Finisher Flag Latch sensor> 4A3-4180-000
              That part is listed on Finisher W1 Part Book as behind Finisher Latch Cover/which u remove when u install a Puncher
              The Flag engages Puncher Latch Unit black button .
              • SCREWTAPE
                East Coast Imaging
                • 3396
                Nice find teckat.
