E823 ir550
  • jinjangu
    • Jul 2008
    • 39
    E823 ir550
    what is wrong with E823..when i turn it on, in a very short moment, this E823 appear...i never repair this model before. can some one give me a answer please
  • SCREWTAPE
    East Coast Imaging
    • 3396
    I believe this is a fan error.
    Maybe its faulty or check the connector.
    • CanonSco
      Man About Town
      • Jul 2010
      • 368
      Is this a GP605 variant model? ( IR550 not available here )
      If so E823 is a fault with the Pre-Transfer charging assembly FAN. Which goes back to connector J504 on the DC Controller.
      Yes, I am a nerd.
      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        E823 Pre-transfer charging assembly fan FM10, as already pointed out by CanonSco
        • Alan Aya
          [QUOTE=jinjangu;153090]what is wrong with E823..when i turn it on, in a very short moment, this E823 appear...i never repair this model before. can some one give me a answer please[/QUOTE
          When did this error code comes on?Is it after you service/ take out the processing/drum assembly? If it is ,check the connector of the Fan(FM10), might be the connector is not connected. If the machine is ok all this while, out of sudden the error code show, it could be the DC controller is faulty as CanonSco had earlier mentioned.
          • jinjangu
            • Jul 2008
            • 39
            the machine was totally out of order and it was not turned on because of the lamp carriage problem when i reached, immediately, i opened all the cover in front, the console panel, the platen glass and the hopper..after i had fixed the lamp carriage, i put back all things. when i turn it on, the error code appeared..
            i guess i haven't put back one of the connector...thank you Alan...and all the above
