Canon IR C3170U different codes E0020, E0021, E0026, E0803
  • Desert Rat
    • May 2008
    • 1089
    I got through most of the codes. It does need yellow toner. Looks like the whole bottle came loose
    on the inside. The patch sensor was dirty and there is a lot of yellow toner in this machine.
    The transfer belt does not clean itself. The drum looks like the cleaning blade needs to be cleaned,
    unless it is transfering from the transfer belt? More yellow toner. I did get it to feed. These guys
    bought this at an auction.
    How hard are these machines to work on? And are they worth the trouble?
    DR
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Blow it up!
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Originally posted by SCREWTAPE
      Blow it up!
      I concur with Screwtape, the 3100/3170 can be a beast. That auction item would have been better passed over. These typically required a great deal of service, for minimal color quality. The cost of parts that this machine needs probably far exceeds its value. Good luck!
      • teckat
        • 16083
        DR
        • Desert Rat
          • May 2008
          • 1089
          Thanks for your open opinions. I was afraid that is what I would hear.
          Well, I will tell the customer. Sounds like it is not even worth fixing?
          To bad, these guys are excited about selling this box for about $2500. They said it was to good of
          a deal to pass up. Now they will find out why it was such a good deal.
          To bad, I hate smashing someones dreams with facts
          DR
          • SCREWTAPE
            East Coast Imaging
            • 3396
            It is what it is.
            • teckat
              • 16083
              thieves at work~~~~~~~~~~~~~~~
              • Canuck
                Tech Specialist
                • 1713
                EDSEL
                • Desert Rat
                  • May 2008
                  • 1089
                  I was told the customer found a wholesaler in Calif. to buy it for $1100 as is. Sounds fishy.
                  DR
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    they no doubt are buying it as a parts machine,,, but I believe they are actually paying too much for it, but let that be their problem ;-)
                    • teckat
                      • 16083
                      DR
                      take the money and Run far away ~~~~~~~~~~~~~~
                        Blow it up!
