can an1 plzzz help me regarding d firmware of irc 3100 where do i get it plzzzzzz help
irc 3100 firmware
To understand Canon units,your best bet is to First post for machine manuals that you need in the > MANUAL FORUM on this site, good luck in your search
http://www.copytechnet.com/forums/se...nual-requests/
You do not need Firmware if machine is working, Firmware updates are used only when machine has issues. Firmware for HDD errors is another issue.
You also need the Canon SST ( SERVICE SUPPORT TOOL ) to install firmware on it's products, and a understanding of how and when to use this tool on the different Canon models. All Canon units are not the same when it comes to using Firmware.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I believe his story, just an entrepreneur trying to make something of himself. But buying the equipment is only half the process, he will need to invest in the tools that will allow him to service the copiers as well."Once a King, always a King, but once a Knight is enough!"
in india we've a system 4 refurbished machines dere are around 8 to 10 importers who import d machines and then there are persons who buy container 4m such importers or half of dem & sell it 2 end users etc or sell it on rental basis(as in my case) so am i clear i've some technicians who repair d machines wen broken down & I also take a huge interest in dis machines we dnt get any softwares 4m such importers thgh dere are some persons who format d hard disk & convert d copiers to netwrking & all so I thght to learn & do it by myself & dis forum was dere to help meComment
that's all great information. But if you read my post above about Canon Firmware & Canon SST, you will see it is not easy to apply or learn from books/all Canon series/machines are different. You do not need to Format the HDD to Network a machine.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
