IR2800 skewed feed tray1, broken plastic spring retainer tab
  • xeroid
    Document Technologies Pro
    • 148
    Fig 310 in pc depicts only one spring idler roller and does not number the plastic guide as a spared part. I could likely pull the assy and repair by drilling a small hole and inserting a self tapping screw to hold the spring if I could figure out how to safely remove the pick-up mount assy. I removed the mount screws from the lwr right side but it appears much more is holding the assy in. Don't want to break anything. Any advice or experience?
  • CanonSco
    Man About Town
    • Jul 2010
    • 368
    Hi Xeriod,
    You need to take out the whole PPU/Mount assy. Then ideally replace the PPU or use the following field part.
    pix1..jpg Spring lug broken
    pix2..jpg Replaced with arm
    Part number of arm kit FA9 3948 000
    Yes, I am a nerd.
    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
    • xeroid
      • 148
      how does that mount come out? I removed the screws behind thr right covers but it felt like alot was still holding it in. Don't want to break anything
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1250
        There's another screw to at the top right of the ppu recessed further in. Get a longer screwdriver and find that screw and it should come out fine.
        • mrfixit51
          Lead Service Technician
          • Oct 2008
          • 1975
          It has been a long time, and I only had to do it once,,, but doesn't the replacement bracket simply pinch in over the existing plastic guide area? I don't recall having to remove the paper feed assembly to make this repair. I know they used to make a left hand as well as right hand repair clip.
          FA9-3948-000 PLATE 4 /IR3300 FA9-3949-000 PLATE 2 /IR3300
          • blazebusiness
            • 1250
            I believe you are correct. I Don't know why the whole ppu would need to be removed to perform this repair.
