iR ADV C 7 / 9 series, black and white / color recognition for the plaintiff
  • canonjh
    • 39
    COPY color when the plaintiff is aware that the adjustment mode when not.- Same color models -COPIER> ADJUST> MISC> ACS-ADJ entries -3 3 (-3 adjustable)
  • teckat
    • 16083
    Plaintiff= do you mean The Customer ???
    please explain / do u mean Auto Color Detection of Document on Glass / Copying_Scanning ???
    This model is different than imageRunners when it comes to adjustments/ u need to be trained on imageRUNNER ADVANCE models or study the many manuals for it.
    COPIER>ADJUST>MISC
    ACS-ADJ Set criteria for B&W/color in ACS:front
    Lv.1 Details To set the judgment level of B&W/color original in ACS mode.
    As the value is increased, the original tends to be detected as
    a B&W document, and as the value is decreased, the original
    tends to be detected as a color document.
    Use case When adjusting the color detection level in ACS mode
    Adj/set/operate method
    1) Enter the setting value (switch negative/positive by -/+ key)
    and press OK key.
    2) Turn OFF/ON the main power switch.
    Display/adj/set range -3 to 3
    Default value 0
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Strange!
      • teckat
        • 16083
