Need Help of Canon IR105
  • addoncopier
    • Feb 2010
    • 114
    Thank you very much. By the way teckat, IR4570 have U-send function right? If i scan document from feeder and store in mailbox, after that can i use the u-send function to send that document to the PC in PDF.
      • 16083
      • Specifying a destination
      • Selecting a file format
      Press to select the file format of the document you are going to send
      • Specifying the Send settings
      • addoncopier
        • Feb 2010
        • 114
        Teckat, Now i want to repair the Cassette 2. The problem right now is, i put paper into the tray. Paper do lift up but screen show that no paper inside. What is the problem?
        • addoncopier
          • Feb 2010
          • 114
          #19
          Teckat, again the problem come back. This time i run A4 for both cassette 1 and 3, paper jam at 0205. But when i try to run A4R no problem. What is the problem?
            • 16083
            #20
            do u look at control panel to check and see that the correct size paper A4 is listed / shown on screen when u place it in #1 & 3
            • addoncopier
              • Feb 2010
              • 114
              #21
              Size of paper sometimes is 288 and 284mm at the *28* copier > CST-STS
              • SCREWTAPE
                East Coast Imaging
                • 3396
                #22
                And??
                • addoncopier
                  • Feb 2010
                  • 114
                  #23
                  Coz i check other machine it is 297mm. so just want to make sure is it because of the changes, causing paper jam at 0205,0209...
                    • 16083
                    #24
                    forget about service mode
                    A Simple ?????
                    WHAT DOES THE CONTROL PANEL LCD SHOW WHEN U CHANGE PAPER
                    iR105 demo link below
                    • addoncopier
                      • Feb 2010
                      • 114
                      #25
                      A4 paper. All normal...It just dunno why, running for maybe 20mins or even up to 2 or 3 hours, then paper jam. and code is the same 0205,0209. But A4R no problem whole day...
                      • addoncopier
                        • Feb 2010
                        • 114
                        #26
                        by the way,Transfer charges primary easily get E069 code. Is it this also will cause 0205,0209?
                          • 16083
                          #27
                          did u change those deck feed clutches ?
                          u could have an Arc issue while printing.
                          BEST BET GO GET A iR105 SERVICE MANUAL
                          Only u can view these issues
                          Many things can cause E069 on this model
                          E069 code indicates a fault with the transfer charging assembly. Additionally, a bias voltage is applied to the fuser assembly and the paper feeder guide and if this bias voltage shorts to the frame it will cause E069 codes. There are two simple checks that can be made to check for the bias voltage shorting to frame ground.
                          The diagram below illustrates how to check for a bias short in the paper feeder guide. There shouldn't be any continuity at the two points in the photo below, where the black lead is simply on the frame ground. If it is shorting to frame ground, check for wear on green bushing on the registration roller shaft.
                          The diagram below illustrates how to check for a bias short in the fuser roller. There shouldn't be any continuity at the two points in the photo below, where the black lead is simply on frame ground.
                          Also Check upper and lower fuser rollers for wear on bearings/bushings. Uneven nip pressure due to wear may short out fuser bias resulting in E069.
                          • When E069 code is occurring, inspect the rear side of the Fixing / Feeder Frame Assembly for physical damage.
                          • Physical damage to the rear side of the Fixing / Feeder Frame Assembly can cause the Feeder High Voltage cable or the Fixing High Voltage cable to arc to the frame which will load down the High Voltage Transformer pcb's and cause the E069 code.
                          At the rear side of the Upper Fuser roller there is a Fixing Bias tab that can become bent or deformed. At this point, arcing can occur which will load down the High Voltage Transformer causing the code. Check and make sure the Fixing Bias tab is making direct contact with the Fixing Bias line plate and is not contacting the frame of the Fuser unit.
                          • Remove and inspect the Pre-Transfer Corona Assembly.
                          • Clean the Pre-Transfer Corona Assembly and restring the charging wire.
                          • Check to make sure that the Pre-Transfer Corona Assembly is properly installed (misalignment may cause E069 codes).
                          • addoncopier
                            • Feb 2010
                            • 114
                            #28
                            I found that the fixing bias tab as shown in "green arrow" is not contacting with anything just hanging there....So i make it contact back now...
                              • 16083
                              #29
                              give that person a front seat
                              • addoncopier
                                • Feb 2010
                                • 114
                                #30
                                Teckat if the clutch have problem why when i run with A4R no problem. Only A4 have problem? By thw way, Last time this IR105, the fixing motor was Using IR8500 fixing motor, once i notice i replace with IR105. after that this 0205,0209 paper jam prob occur...
