Need Help of Canon IR105
  • addoncopier
    • Feb 2010
    • 114
    MY IR105 always facing paper jam at this area 0205 and 0209. I try cassette 1,3, also same. because cassette 2 and 4 cant work.
  • teckat
    • 16083
    stationary jams=02
    Jam 0205= Inspect & or Replace CL9
    Jam 0209=Inspect & or Replace
    Brake Clutch in Deck
    • addoncopier
      • Feb 2010
      • 114
      Originally posted by teckat
      stationary jams=02
      Jam 0209=Inspect & or Replace Brake Clutch in Deck
      Sorry teckat, can you post the picture of CL9? hehe...if possilbe show me with photo..coz i really dunno all the part of machine. i just very simple thing. change corona, change sponge roller, and maybe clean clutch with paper...
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        The 105's seem to rust clutches out at an alarming rate and there should be visible signs of rusting....better to replace than clean up due to the sheer volume of these machines.
        • teckat
          • 16083
          sorry teckat, can you post the picture of cl9? Hehe...if possilbe show me with photo..coz i really dunno all the part of machine. I just very simple thing. Change corona, change sponge roller, and maybe clean clutch with paper...
          cl9 is on the vertical path drive assembly
          fg6-8577-030 > Double click on picture
          fh6-5043-020 cl9
          deck N1 / Brake feed clutch=Quantity 2 /CL1-CL2= FH6-5043-000.
          Verify that enough play is given to clutch wiring harness
          deck M1 / " feed clutch = Quantity 2 /CL1-CL2 =FH7-5826-020
          • addoncopier
            • Feb 2010
            • 114
            Teckat, I clean up the cassette 1 both clucth and registration both clutch before Transfer....now become 0205,0209,0101....And the cassete 1 when paper feeding, sound like a bit delay...haha..
            • teckat
              • 16083
              [ATTACH=CONFIG]5658[/ATTACH]
              Replace not Clean- hehe'
              • addoncopier
                • Feb 2010
                • 114
                Cassette 4 i m not using, so i exchange both clutch. Still the same problem....0218 appears now...So, i need to replace the Brake clutch of registration right? In malaysia a lot of poeple hate IR105. But i want to used it because Very fast and now getting cheaper...Only RM7500 can get 1....
                • addoncopier
                  • Feb 2010
                  • 114
                  Teckat, By the way do you have service manual of IR105, can send for me? emial address addoncopier@yahoo.com
                  • andy21557
                    Help Desk Technician
                    • Jul 2009
                    • 62
                    check for burnt or missing pin on the connector for the feed head on deck 1 .. may have been burnt by touching the connector w/ screwdriver while unit is powered on .. another tech did it once and replaced the pin w/ a staple and didnt note in the log ... i spent days chaseing the code
                    • teckat
                      • 16083
                      FH6-5014-020= CL3 Reg brake CL
                      • addoncopier
                        • Feb 2010
                        • 114
                        Teckat, i just replace the CL3. Cassette 3 running 10reams of paper no jam. But cassette 1 still the same. 0205,0209,0218
                        By the way, i notice the "CST-STS" WIDTH MF-283mm,sometime 280mm...If not mistaken it suppose 297MM right? why the number changing?
                        • teckat
                          • 16083
                          0218 0205 0209 jam code when feeding out of deck 1.
                          Check pin contact on J229 of the Right Deck Intermediate connector
                          Replace and check wiring of the deck 1 feed clutch FH6-5043-000
                          Jam code 0218 can be caused by CL5 and the registration clutch. Check PS60 flag for cuts and also putting a extra wrap on the sensor flag can resolve the jam code.
                          CL5=FH6-5016-020
                          • addoncopier
                            • Feb 2010
                            • 114
                            I adjusted the selonoid of deck 1 now temporary runnning ok...
                            • teckat
                              • 16083
                              good work !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
