canon np1020 no life
  • landspeeder
    • Feb 2010
    • 355
    Customer brought in her 1020 thats in awesome shape. There is no life ie display, fan noise etc. Fuses check out and the 12v, 10v dc etc. is there. Can it be a switch , should not at least the fan run or something when the power seems to be alright?
    D
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • milldew
    • Mar 2010
    • 22
    Check the interlock switch on the fuser door. Its just a piece of flat metal that can bend and not actuate the switch, front side of door. Also check the main interlock, less likely that one. Either one will kill power to the machine.
      • 22999
      From the database: Possible bad scanner driver PCB.
      Personally I'd spend more time with the main power switch and power supply. Do you have any voltages at the PS?
      You know, I liked these little machines. We had them in some horrendous environments: factories, gravel pits, welding shops, etc. Sure they got dirty, but cleaned up OK, and survived amazingly well.
      I doubt that you can get any parts. Good luck. =^..^=
      • landspeeder
        • Feb 2010
        • 355
        Ive pushed that fuser door switch on and off today 10x at least with no luck. When I was posting this issue, I went back to the machine and it was working....its the fuser door switch, so I've just sprayed some contact cleaner/lub at it and lets see what tomorrow brings.
        Thanks!!!!!
          • 16083
          Thanks!!!!!
          way to go/works all the time
          • milldew
            • Mar 2010
            • 22
            Your welcome, I just worked on a 1010 today, oddly enough. We have several machines parted out, and as far as I know Canon still has parts available.
            PS- just checked on Canon, only a few parts still avalable. Drums, toner - yes. fuser , DV- no. We have alot of 1010, 1020 parts in stock if you need them.
            • landspeeder
              • Feb 2010
              • 355
              sounds good thanks again!
              • landspeeder
                • Feb 2010
                • 355
                so I just went and powered the unit up, after being off all night, and its not working. I just wiggled the switch etc. and nothing. Yesterday when it came on it had been ignored for a couple hours when I just happen to look over at it and it was on. So it wasn't something we did at the time. Hmmmmm, I am going to leave it on and see what happins. Stay posted! Unless anyone has a idea
                • landspeeder
                  • Feb 2010
                  • 355
                  Here is the update...I just walked by the unit heard some noise and away it went. So from the time it was turned on it took about 3-4 minutes before anything occurred. Any ideas?
                    • 16083
                    remove the heater lamp and inspect/ i'll bet it looks bad
                    • Herrmann
                      • Jan 2006
                      • 792
                      if the fuser lamp is bad, the unit would at least power up and show an error.
                      my bet goes to the power supply, check it for bad soldering joints.
                      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                        • 22999
                        I agree about the power supply. =^..^=
                          • 16083
                          Not exactly true/ i have had lamps that test good in this model/ but when u remove them , they look like hell/ and no error codes
                          u can buy these machines cheaper than it is to repair
                            • 22999
                            teckat, was this the model that the heat lamp used to expand within the heat roller, but not blow, so that you couldn't get the lamp out, or the heat lamp began to warp like a banana? =^..^=
                              • 16083
                              Yes, that lamp is crap. the board in back used to burn out also, -also w/no error code shown
                              I used to re build these in a shop many years ago, taking that fuser unit out was a pain in the Butt
