NP6545 E000
  • Ducttape n Glue
    • 195
    NP6545 E000
    Hi, its been awhile since we serviced a Canon NP copier. I have a customer with an NP6545 with an E000 which is usually a fixing unit heater issue, thermistor, fuse or lamp most common. If I remember right, there is usually a reset for the fuser codes for enduser safety. Could someone tell me the reset? If you like it can be thru PM also. Thanks , appreciate it. DnG
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1258
    Thats easy........poke a clip thru small hole inside front door-------$ sign comes up on display. Now you can enter service mode. You need *4* then go thru screens to "error" & reset it. Good Luck--------------Blaze
    • Ducttape n Glue
      • 195
      Blaze,
      Thanks, appreciate the quick response, gonna go there myself.
      DnG
      • blazebusiness
        • 1258
        no problem-------glad to help
