Canon IR 7105 error code
  • heera
    • Jul 2009
    • 8
    [Error Code] Canon IR 7105 error code
    I have an issue in IR7105 it gives an error after boots up E110-000. How to sort this i have checked all fans realted to LASER units its working. Can anybody help to sort
    Thanks in advance.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Replace the laser unit. No other choice.
    Are you a canon authorized dealer?
    Quite costly!
    • nivssluck
      • May 2008
      • 228
      Check the laser shutter. Check the plastic cover of the primary corona if present or maybe broken. You can see the shutter above it.
      • montana
        • Aug 2008
        • 392
        hi...this error code is related to the laser unit..so you should check the shutter if it is moving correctly or something wrong with the unit...otherwise you should check the DC controller PCB
        i hope it is help..thanks
        • teckat
          • 16083
          Thanks in advance.
          If you are an AUTHORIZED DEALER
          Free of Charge Repair Program for failed imageRUNNER
          7105 Series Laser Scanner Units (FM2-5449-000).
          In order to qualify for the Free of Charge Repair, the Laser Scanner Unit must meet these criteria:
          1. The Laser Scanner Unit malfunction must be determined to be caused by a failed Laser Diode(s) which results in
          one or more of the subsequent malfunctions:
          a. An E110-0000 Error Code
          b. Light Images (Low Density)
          c. Mirror Images
          The Authorized Parts Repair Facility of your choice will perform testing and make
          the determination if the diode has actually failed.
          Confirm the Lot Number of the Laser Scanner Unit is 32022578 or lower.
          Ensure sufficient packing is used (such as the box from a new Laser Scanner Unit). The Laser Scanner Unit must
          arrive at the APRF without any shipping damage.
          A complete and accurate Laser Scanner Assembly Repair Request Form must accompany each Laser Scanner Unit.
          • SCREWTAPE
            East Coast Imaging
            • 3396
            c. Mirror Images
            Done this about six times. $9000 was what we spent to replace these laser units. If your authorized you can send the laser unit to HYTEC. Hytec will fix them free of cost if your authorized and Canon will absorb the cost. We now got some in stock.
            They must fit the guide lines,
            c. Mirror Images
            • nick55
              • Jun 2010
              • 51
              how do you prevent this from happening again after replacement? any changes in laser settings after installing the repaired unit? i'm just curious if this problem fix already on higher lot number laser unit?
              c. Mirror Images
              • nick55
                • Jun 2010
                • 51
                can you give some idea how much is repair cost?
                Quite costly!
                • teckat
                  • 16083
                  where have u been for 6months ??
                  READ>>>>
                  U must work for a Authorized Dealer to even think about free replacement
                  Ensure sufficient packing is used (such as the box from a new Laser Scanner Unit). The Laser Scanner Unit must arrive at the APRF without any shipping damage.
