error message on imagerunner C5158
  • citycopiers10
    • Jul 2010
    • 10
    [Dead] error message on imagerunner C5158
    hello,
    Error message: E000004-0401. It's a ImageRunner C5158. Can anyone help please!
    City Copiers is the nations leading seller of lightly used copiers.
  • teckat
    • 16083
    Originally posted by citycopiers10
    hello,
    E004-0401 can be displayed when a 13V trouble error occurs.
    Note: Unlike the other E004 series codes, this code is not be cleared until the error clear is performed in the following mode: [Service mode > COPIER > Function > CLEAR > ERR].
    E004-0401
    - E004-0401 can be displayed when a 13V trouble error occurs.
    1. Make the following selections in sequence to perform the error clear:
    2. Turn the control panel switch OFF > turn the main power switch OFF/ON.
    3. If the error code still persists, check to see if the connector [1] of the fixing thermo switch is disconnected or the pin [2] of the receiving side connector is bent. If the connector is disconnected, re-fit it.
    4. Check to see if the wire cable [3] of the fixing thermo switch is pinched by the IH heater unit.
    Note: When attaching this wire cable, run it through the cable guide to prevent wire-pinching.
    5. Re-fit the connector of the Replay PCB.
    6. Check to see if FU261 on the Fixing Heater PCB blows; if not, re-fit the connector.
    If it blows, replace the PCB by a new one.
    FM2-6313 Fixing Heater PCB Assembly
    E004-0401: J623 connector of Relay PCB has poor contact
    13 V trouble error
    Since J623 connector (13V/5V for fixing heater power) or the Relay PCB had poor contact, the error code "E004-0401" was displayed.
    - E004-0401 can be displayed when 13V trouble error occurs.
    Note: This is the only error code that is in-volatile. To clear this code, execute the following service mode: Service Mode > COPIER > Function > CLEAR
    > ERR.
    1. Re-fit J623 connector of the Relay PCB.
    2. Check to see if FU261 on the Fixing Heater PS PCB has blown; if so, replace the PCB with a new one.
    3. If the symptom still occurs, check the fixing thermoswitch connectors for poor contact, and read wires for wire-pinching.
    FM2-6309 Relay PCB Assembly (100V/120V)
    FM2-6310 Relay PCB Assembly (230V)
    FM2-6313 Fixing Heater PS PCB Assembly (100V/120V)
    FM2-6314 Fixing Heater PS PCB Assembly (230V)
    • teckat
      • 16083
      hello,
      E004-0101
      E004-0101: Halogen heater is damaged or terminal of heater has poor contact.
      Because of damage to the halogen heater (H1) or poor contact of a heater terminal, the error code "E004-0101" was indicated. This error code may be indicated due to a fault in the AC Driver PCB (i.e., triac short), the fixing assembly, and the DC Controller PCB 2 (MAISY). However, before replacing these parts, perform the following procedure.
      - E004-0101 can be displayed when there is a short-circuit detection error in the halogen heater (ASIC detection).
      Workaround :
      1. Detach the terminal on both ends of the halogen heater, and then check to see if the heater has electrical continuity; if there is no electrical continuity, replace the heater with a new one.
      2. Check to see if the terminal [A] on both ends of the heater is fixed firmly with a screw. If the screw is loosened, tighten it.
      3. If the symptom still occurs, check to see if J114 connector of the AC Driver PCB is disconnected. If disconnected, re-fit it.
      FK2-2532-000 Halogen Heater (120V)
      FM3-0266-000 DC Controller PCB 2 (MAISY)
      FM2-6301-000 AC Driver PCB
      • charm5496
        • 2387
        Replace your fuser assembly
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Very costly.
          Good luck.
          • citycopiers10
            • Jul 2010
            • 10
            E004-0401
            13 V trouble error
            > ERR.
            [ATTACH=CONFIG]5676[/ATTACH]
            Thank you so much for sharing these. It seems the J623 connector is the problem, I'll be replacing the PCB...hope it will work.
