CANON IR5000
  • hamdyyassin
    • 84
    CANON IR5000
    Can i change a canon ir5000 110v to 220v model
    thanks for help
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    No, you can not.
    There are far too many components that different between them to even consider it.
    • teckat
      • 16083
      thanks for help
      NO U CAN NOT, with out changing many components /
      U can try a Heavy duty Voltage Power outlet converter / don't know if it will work on this large printer
      • sgcopiertech
        No you can't, but you can use an external step down transformer converting 220V to 110V.
        • ESA
          You'd need one heck of a step down transformer that can generate the current needed to run the machine. You should look to a larger product if you dont want it get messy like a ir7200 or higher. That is unless your choices are limited.
          • costd
            • Jan 2008
            • 409
            Let us not forget
            If you are trying the 110 - 220 trick, I suspect you need to look and see if the 60Hz vs 50Hz issue comes into play. As others have said, can it be done - yes, but the number of items that need replacement negates consideration.
            I was involved in a situation where we needed to make a 60Hz run where the local power was 50Hz. We "engineered" a monster where we took in the local power to a BIG battery charger, then took the battery unit (I think it was 7 large floor units) output into a modified (read giant) inverter and resulted in 110v 60Hz BUT IT WAS NOT CHEAP (Uncle Sam) and we still had intermittent issues.
