We have a new customer with a Canon IR3570 with an odd problem. It will not fax from memory. The last company told them (to avoid the issue) to manually fax (wait for handshake and hit start to fax) which works fine. If you try to fax from memory or try to fax from desktop it immediately goes into redial and eventually errors out. As far as I can tell it never opens up the phone line. Any help would be appreciated. Thanks in advance.
Canon IR3570 Fax Issues
I don't know if your Canon has similar fax settings, but this may help:
http://www.copytechnet.com/forums/ky...gone-nuts.html
=^..^=If you'd like a serious answer to your request:
