E-000045-0000
  • wulffservice
    Service Team ******
    • Jul 2009
    • 29
    [Error Code] E-000045-0000
    Canon Color Image Runner C3380i has an error code E-000045-0000. Have no clue what it is or how to clear it can anyone help.Thanks
  • Gamut
    • Jul 2008
    • 216
    OHP sensor error, clean or replace.
    • CanonSco
      Man About Town
      • Jul 2010
      • 368
      As above , OHP sensor is more than likely popped out of its holder / bracket.
      Only ever had to replace one.
      Yes, I am a nerd.
      Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
      • wulffservice
        Service Team ******
        • Jul 2009
        • 29
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Check out my thread on http://www.copytechnet.com/forums/ca...-models-3.html. There's some photos of the sensor.
          • teckat
            • 16083
            pain in the butt to replace that OHP sensor/
            • edpianix@yahoo.com
              error code e000005-0000
              my copier displyed call for service error code e000005.0000
              please help me what to do and how.
              thanks
              Eddie
              • teckat
                • 16083
                what model ?
                • blazebusiness
                  SanDiegoCopierRepair.com
                  • 1250
                  thanks
                  Eddie
                  This post is for a IRC-3380 which has no E005 code. For future reference you should have started a new post and list the model of the machine giving you that code. An E005 usually refers to a cleaning web out issue.
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    thanks
                    Eddie
                    Call a local copier company for a tech to come out and replace that web.
                    There is additional procedures to be taken after the web has been replaced.
                    You should have created a thread for your issue.
                    • dan7777
                      • Dec 2012
                      • 680
                      Re: E-000045-0000
                      Do you know of a video or instructions on how to take out the plate (guide) the sensor is on? I need to get the registration roller out to change the left bushing. I got the registration clutch off but there is not enough play to get the bushing off. I think I need to take out the plate (guide) the OHP sensor is on.
                      • teckat
                        • 16083
                        Re: E-000045-0000
                        u talking about the 3380 ??
                        no one ever takes out that roller / or plate--why are u changing that bushing
                        if u have a z fold or a buckle to paper or jams or Mis-registration?--- it's the flag behind that plate that sticks to a rubber damper pad in back of plate-
                        (Remove the noise dampening pad for the Registration sensor flag)
                        u can't see the pad -- location is just to the right of opening (OHP) behind plate> take a spring hook and scrape off that pad (black rubber)
                        • Rachid.Akli
                          • Oct 2011
                          • 595
                          Re: E-000045-0000
                          Hi to every one
                          Note that there are two separate parts for the OHP sensor: The emitting/recepting part which is in the machine body and the reflecting part which is in the lower left door. You can clean both parts. If the issue is not solved and if you have to replace the reflecting side, take care to mark its position before disassembling it. It is hard to find the right position if not marked. The extreme solution is to replace the whole left door.
                          Rachid
                          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
                          • northernlife
                            • Sep 2011
                            • 847
                            Re: error code e000005-0000
                            thanks
                            Eddie
                            We need a model number. There's no e005 for the 3380 as there's no fixing web.
                            • teckat
                              • 16083
                              Originally Posted by edpianix@yahoo.com my copier displyed call for service error code e000005.0000
                              thanks
                              Eddie
                              that post u reply to is from 08-13-2010
