E-000045-0000
  • dan7777
    • Dec 2012
    • 680
    #16
    Re: E-000045-0000
    Originally posted by teckat
    u talking about the 3380 ??
    no one ever takes out that roller / or plate--why are u changing that bushing
    if u have a z fold or a buckle to paper or jams or Mis-registration?--- it's the flag behind that plate that sticks to a rubber damper pad in back of plate-
    (Remove the noise dampening pad for the Registration sensor flag)
    u can't see the pad -- location is just to the right of opening (OHP) behind plate> take a spring hook and scrape off that pad (black rubber)
    [ATTACH=CONFIG]18861[/ATTACH]
    Thanks for the reply. I put up a photo of the left bushing for the registration roller. A piece of the ramp is broken so the pin on the transfer roller assembly falls down and gets stuck. I had to replace the right door because it was so bent up. I took a thin piece of copper and taped/glued it to cover the hole but the pin still gets stuck opening the door (not as bad) because it is not smooth. I can see why no one ever changes the bushing. The part on your picture of the damper pad behind plate I think is why the bushing will not come out. I got the registration roller clutch out but there was not enough play to get the roller out far enough to put in the new bushing (the gear hits the other bushing). I gave up and because it is a two hour round trip, my boss is putting off the call for now but it needs the bushing and I am not sure how the plate comes out.
    • teckat
      • 16083
      #17
      Re: E-000045-0000
      it takes various parts to be removed--to get that plate off
      there are no directions in manual/ never was it ever covered in training<
      I took it off once> cant remember what was removed> it was a trial n' error
      found out that it did not have to be removed-- will ask around
      • dan7777
        • Dec 2012
        • 680
        #18
        Re: E-000045-0000
        Originally posted by dan7777
        Do you know of a video or instructions on how to take out the plate (guide) the sensor is on? I need to get the registration roller out to change the left bushing. I got the registration clutch off but there is not enough play to get the bushing off. I think I need to take out the plate (guide) the OHP sensor is on.
        I uploaded the photo of the broken bushing again.
        • teckat
          • 16083
          #19
          Re: E-000045-0000
          don't see your photo--------re-post it
          • teckat
            • 16083
            #20
            Re: E-000045-0000
            [ATTACH=CONFIG]18867[/ATTACH]
            so u need to replace that plastic ramp and roller bushing ???
            • dan7777
              • Dec 2012
              • 680
              #21
              Re: E-000045-0000
              [ATTACH=CONFIG]18868[/ATTACH]
              Yes.
