restarting m2 imageruner
  • vazgen
    • Jul 2025
    Afetr reciving files M2 imageruner restarts .what is the problem.
  • teckat
    • 16083
    U mean the imagePass M2- what printer model is it on ??
    Run a Hardware Diagnostic Mode on the imagePASS M1 / L1 /M2
    1. Reboot the imagePASS M1 / L1 / M2.
    2. When prompted with the 'Press any key for Config Mode' message, press any key.
    3. The Config Mode menu will appear. Select Diagnostics. * This Diagnostic Mode will allow you to test all the hardware on the imagePASS M1 / L1 / M2.
    Note: You can test the imagePASS M1 / L1 / M2's connection to the imageRUNNER by selecting Run Diagnostics from the idle menu (when the M1 / L1 / M2 is booted to idle). These diagnostic tests are very different from the Hardware Diagnostics Mode available in Config Mode.
    U May have to re-load firmware on M2
