Is this true????
  • tinnyjay
    • Oct 2009
    • 663
    Is this true????
    Hello!
    We are a company in Albania and we buy refurbished copiers(Toshiba,Canon,Ricoh) in Switzerland,and sell them in Albania.
    Mostly of copiers are(were) Toshiba E-Studio and our staff is qualified for this brand.
    Before 1 years we started to import Canon color copiers and we had too much problems with old models,like IR3100CN and one day a guy from another Company come to us(friendly) and when he saw us trying to repair one(all parts down on the ground),he said: "You do not need to do this,because you cant repair them.We are 10 Canon Trained Techs and we cannot repair them,without changing all boards,because after some years,this models of copiers,all have problem of "clocking".You try to make a copy,and transfer belt,drum and paper feed do not move in synchronous and you got problems on copying(quality,image),without showing an error code."
    I just rejected his word and say to him that this cannot be true,because if motherboard has problems with clocking,it will showes an error at any time.
    IS THAT TRUE WHAT HE SAID?
    "Who loves the roses,must also bear thumbs"
    Its not true, but the IR3100c family is a high maintenance machine. Toner gets sprayed around inside the machine, the fuser gets flat spots and the drum life is very short if the customer does a lot of colour.
    • deep
      • Jun 2008
      • 208
      Some years????? It's my concern to know in how many years that the clocking issue happen. Perhaps my machines would last for decades or even for centuries.
      Kenny
      • costd
        • Jan 2008
        • 409
        Then again
        This could be another case of a machine built for use in the US (60Hz) is being used in Europe (50Hz). Not a case of 120v vs 240 (which can be handled via transformer) - but the difference in Hz will cause timing (clocking) issues.
        Check the power supply and see if it is expecting 60Hz - if so, lots of parts need to be changed (as he was talking about), or you need to run it off a battery/inverter that can do 60Hz.
        Actually I hope this is not your problem as if he has 10 techs and none knew .......
        • CanonSco
          Man About Town
          • Jul 2010
          • 368
          Yes , the 3100 is a high maintenance machine. BUT this doest bode well for his "techs". Maybe they need additional training. Think the next time I go to one I will change "all the boards"
          Yes, I am a nerd.
          Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
          • nmfaxman
            • 1702
            Upload some samples and let us all see what's happening.
            It may be a TIMING problem.
            • tinnyjay
              • Oct 2009
              • 663
              There is no sample,but he was just talking generally for that model.
              • blazebusiness
                SanDiegoCopierRepair.com
                • 1257
                Not true - and I'll bet you that Costd nailed it with the supplied power issue 60hz versus 50hz comment he made.
                • teckat
                  • 16083
                  No Error Codes/No Jam Codes during Operations /always = A Supply POWER ISSUE
                  • tinnyjay
                    • Oct 2009
                    • 663
                    In Europe our electricity frequency is 50 hz and all copiers come to Europe are 50 hz,no doubt,but he said that problem of "clocking" comes from motherboard not from power supply.
                    • blazebusiness
                      • 1257
                      He may have said that it comes from main board but I've never seen "clocking" with this model and we have worked on plenty. The "quote 10 Canon trained techs" could do nothing with these? Then some guy from "another company" came by and said they need to swap all the boards? The whole thing sounds funny to me. Makes me wonder about those techs...........
                      Good input by Costd though-----
                      • mrfixit51
                        Lead Service Technician
                        • Oct 2008
                        • 1975
                        Here is the best advice,,, since you are buying used color copiers, avoid the 3100 and 6800 family of copiers all together. Let someone else have that "fun". You would do well to buy the 2620-3200-3220 family of copiers. They were a much more reliable copier, that produced better color images.
                        • blazebusiness
                          • 1257
                          That is good advice but I would add to it to avoid the 2620-3200-3220 family also if you need a good fax or scanner. The Doc feeder sucks. Good printer though.
                          • hemai2005
                            Professional Print
                            • 108
                            sorry our friend from albania or hungria or Belghoria or any place in the world your sinario (bad) sorry again
                            CANON product represent no one,also iRc3100 very good machine....
                            sigpic
                            Learned a lot will become an expert
                            • tinnyjay
                              • Oct 2009
                              • 663
                              Thats real
