Just recieved a phone call from customer - IR 400 wont fax out and has on display scan error 1584. Sounds like it still copies & prints fine but won't know for sure til I go out & see it for myself tomorrow. Any ideas? Thanks in advance-Blaze
Ir 400 recieves fax won't send
does the iR400 have TX setting option to turn OFF "Check Dial Tone Before Sending" ???
1technical_support_pounding_fist_445455.jpg**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Thanks - I'll check that. Customer said it worked Friday and when they came in Monday it wouldn't work.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Ok- DADF-A1 feeder would not work to scan documents-hence the scan error 1585 when trying to fax. Nor will the ADF scan for copies. Turns out a 2 liter bottle of coke exploded when the customer opened it dousing the copier and the coke that ran inside the af dried and gummed up things so the feeder wouldn't work. Of course the customer having a service contract tried to clean up the copier and the walls so the repair would be covered but the carpet clued me in and of course the dried liquid in the interior of the feeder. Can't believe the customer tried to hide the cause though. Gonna sell them a new copier------------thanks Teckat for replying-shooting you some rep power as a thank you.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Thanks, once had a customers girlfriend pour water in all four color toner hoppers on CLC5100, after they had a fight and he left office, funny thing She was his manager. Cost to repair & replace parts was Large , she was fired.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
LOL- Yeah - I've seen some doozys in my day also. It would make for a very long thread to list them all. Thanks again-BlazesigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
