Color Universal Send Kit-
A2P for Color imageRUNNER
C3220,
Universal Send makes it simple to convert color hard-copy documents into
digital files for sending to one or many destinations. With this feature, the enduser
can scan, save and instantly send documents in any of five file formats,
including JPEG, TIFF, PDF and compact PDF.
Note: The Color Universal Send function requires a dongle when installed on
the Color imageRUNNER C2620/C3220.
Need to order Color Universal Send Kit-
A2P from Canon
A simple way to verify that a Resolution Switching Board (Send Board) is installed in the imageRunner is to check in Service Mode.
*28* > Copier > Display > ACC-STS > SEND
SEND will indicate "0" if NO Resolution Switching Board in installed
SEND will indicate "1" if the Resolution Switching Board is installed
or >>>
To identify if the Resolution Switching Board is installed, and installed correctly, first look at the board slot metal covers on the cage unit on the side of the imageRunner. The Resolution Switching Board is NOT installed if the second cover from the bottom has two bumps (nipples) diagonally across from each other. If the plate surface is flat, the board is installed.
The Resolution Switching Board is pictured Below. It is installed in the second PCI slot from the bottom.
imageRUNNER C3200 / C3100 / C3220 / C5800 / C6800
Identify if a Resolution Switching Board is Installed in a Color imageRUNNER
A Resolution Switching Board is required to use the Color Universal Send Kit or G3 Fax Board M1.
To identify if the Resolution Switching Board is installed, and installed correctly, first look at the board slot covers on the cage unit at the back of the imagerunner. The Resolution Switching Board is NOT installed if the second cover from the bottom has two bumps (nipples) diagonally across from each other. If the plate surface is flat, the board is installed.
Next, check that the board is installed correctly. Remove the back cover of the Color imageRUNNER copier.
Once the back cover is removed, the metal plate has to be unscrewed.
Note: When removing the metal plate, be careful not to break the fan wire and not to damage the power supply.
The Resolution Switching Board is pictured Below. It is installed in the second PCI slot from the bottom. Reseat the board to refresh the connections. WARNING: Power off the imageRUNNER before disconnecting any electrical components.
C3220,
A2P from Canon
or >>>
