iR3100CN & Windows 7
  • rajkamal
    • Jul 2025
    I'm trying to install the above to Windows 7 and through Canon's website I can only find drivers for iR3100C which of course is not the same machine.
    I have seen the following post (http://www.copytechnet.com/forums/ca...scan-help.html) which suggests a user is using this machine with Windows 7.
    I did manage to locate the driver off the internet for iR3100CN, but when trying to install it doesn't like me doing it to a Windows 7 machince.
    Thanks in advance for your help!
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Try using a UFRII driver.
    Not to sure if it supports W7
    Also check you bit version for W7, 32, or 64 bit.
    Canon U.S.A. : Support & Drivers : imageRUNNER C3100
    • rajkamal
      Hi
      The link that you have given, if I select iR3100, windows 7 (doesn't give an option of 32 or 64 for windows 7), i get only 1 file which are PPDs file. How do I find UFRII?
      In summary I have a windows 7, 64 bit.
      Thanks again.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        If you scroll down you will see windows drivers for 64bit.
        Also try using a PCL driver.
        Try using a windows vista 64bit driver.
        • teckat
          • 16083
          Originally posted by rajkamal
          Hi
          Thanks again.
          Pick it up here/ under this 1025n model it has latest -UFRII Printer Driver v2.70 32-bit INF file for Windows 2000/XP/Server 2003/Server 2008/Vista/Win 7. This driver adds support for Windows 7.
          v2.70 not under 3100 on Canon site
          pick one/ and check agree to download
          UFRII_v2.70_win2k-vista_INF_x64.exe UFRII Printer Driver v2.70 64-bit INF file for Windows XP/Server 2003/Server 2008/Vista/Win 7 (WHQL Certified)
          UFRII_v2.70_Setup_x64.exe UFRII Printer Driver v2.70 64-bit Setup Installer for Windows XP/Server 2003/Server 2008/Vista/Win 7 (WHQL Certified)
          UFRII_v2.70_Setup.exe UFRII Printer Driver v2.70 32-bit Setup Installer for Windows 2000/XP/Server 2003/Server 2008/Vista/Win 7 (WHQL Certified)
          UFRII_v2.70_win2k-vista_INF.exe UFRII Printer Driver v2.70 32-bit INF file for Windows 2000/XP/Server 2003/Server 2008/Vista/Win 7 (WHQL Certified)
          • rajkamal
            Great thanks - I will give this a go and let you know how I get on.
            • rajkamal
              Hi I have downloaded the top file. What this does is downloads a folder called: UFRII v2.70/us_eng/x64/Driver. Within this you have various DA, IC , XP etc. files.
              What it doesn't do though is creates a driver within Devices and Printers.
              Am I supposed to just copy and past the directory into Windows/ or something? But will this recognise the driver?
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                Drivers don't install themselves, choose "Add a printer" from within Windows, and when it is looking for the drivers, point it to the folder that you just created from the downloaded file.
                The other method is to download the installer version of the driver, which has a front end that guides you through the process...
                • teckat
                  • 16083
                  You can select either method- without installer/ or with installer it depends
                  WITH INSTALLER/=Manually configure printer port/=Standard Install
                  auto find network printer port/=Dynamic Install
                  configure a USB printer port/= USB Standard Install
                  WITHOUT INSTALLER
                  /=Install the print driver for a local or network printer/ =use ADD PRINTER WIZARD
                  Install the printer driver thru a USB connection=USB connection Installation
                  • Canonbloke
                    • 17
                    I have a customer who since installing the windows 7 PCL driver suffers from intermittant jams, I have yet to find a solution.
                    • teckat
                      • 16083
                      your responding to a 3mo. old thread ?
                      what machine are u talking about ?? we are not mind readers here ~~!!!!!!!!!!!!!!!!
                      what model ?
                      what jam codes ?
                      • Canonbloke
                        • 17
                        Sorry i thought this was a thread about the Canon IR3100CN, jam code 0B01 "door open jam" detection by software. I posted this because I have a problem locating the UFR11 driver for windows 7.
                        • teckat
                          • 16083
                          UFR11 driver for windows 7 v2.80
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            The two occurrences are not related,, copier jamming has nothing to do with a PC driver. Look to normal copier maintenance items to resolve your jamming problem, and Teckat has kindly provided the link to the drivers section of the Canon website...
                            • Canonbloke
                              • 17
                              Ok thanks
