IR2200 - Network Print issues
  • caalger
    • Aug 2025
    I have recently tried to connect an IR2200 to the network to make up for the catastrophic failure of another printing device we had (may it rest in peace...). I have no issues getting the network addressing done and it communicating on the network. I am able to ping, it is able to ping, I am able to see it from a client and install drivers, I can send print jobs and it logs the jobs...
    ... but nothing prints out.
    The status of the job is "OK" in the log, but there is no output at all. I have reset the MMI per another thread that I found, but that didn't help (other than to teach me about service mode and how to remove department IDs).
    Can anyone offer advice on another place to look or setting to check? I'm at my wit's end.
    Thanks!
  • anothertech
    • 1771
    Check the version of bootrom, if it ends with a C, then it does not have the print function installed, it needs the N type to print.
    • caalger
      It does have the N.
      • D_L_P
        Self Employed
        • Oct 2009
        • 1196
        The easiest way to check for network print function is Additional Functions-> Report Settings-> Printer
        If you don't have printing capability you won't see Printer as an option.
        If you do have printing capability you will see what PDL languages you have under the Printer.
        Since you mentioned dept ID's and the job log shows "OK", the feature to "print jobs with unknown ID's" might be disabled.
        Look in Additional functions-> System settings-> Dept ID management. Make sure ID mode is off if you don't need it and accept jobs with unknown ID's is set to "on".
        I don't mean to cover old ground but with all Canon's you have to cycle power with the main switch on the right rear side for the settings to take effect. And there is a 60 second delay on power up for any network traffic.
        • ESA
          It sounds like you don't have the pcl or ps loaded on. You need the sst tool to load them and verify the 2200n boot rom is truly in the back as mentioned.
          • kuby
            • Oct 2007
            • 1409
            I had the same problem with a ir5000. Could not find anything that was not set right. Tried for half a day to get it to print. Finally I did a MMI clear and reset up IP and now it prints fine.
            • teckat
              • 16083
              Originally posted by caalger
              It does have the N.
              The imageRUNNER 2200/2800/3300 did not come configured for network printing. To enable network printing, both
              the Network Multi-PDL Printer Kit-C1 and the latest version of System Software for imageRUNNER
              2200N/2800N/3300N must be installed.
              • charm5496
                • 2387
                Also make sure the the firmware for the N boot rom is loaded on the device. Someone could have put the N boot rom in and not the firmware. This would cause you issues trying to print. There should be a spot in service mode under copier>version for the PS/PCL version. If you have dashes there then the firmware is not loaded.
                Other possibilities are IP conflict, printing to the mailbox instead of the print queue
                • Fireblade
                  • Feb 2021
                  • 2
                  Re: IR2200 - Network Print issues
                  Thanks!
                  did you find a solution ? I have the same problem
