Hi, I have 2 sets IRC3220n main unit , Both have no scanner and feeder, only working as network printer. how can we use auto full adjustment without scanner.
IRC3220 Main Unit Auto Adjustment
Tags: 220, amou, business, canon color, color calibration, color drum, color settings, feeder, forgot, front cover, full, imagepass, internet printing, irc, main, network, ops, printer, purchase, scan, scanner, unit, usb
Is there a Fiery Rip present? if this is the case, you can calibrate the Unit via "Command Workstation"If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
Accidents don't just happen. They must be carelessly planned.Comment
My apologize, i forgot to mention it.
Yes sure, you are in need of an es1000 or similar.
sorryIf sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
Do you mean swapped laser from another machine?
If you have replaced or swapped the laser unit, execute the following service mode:
COPIER>FUNCTION>LASER>L-ADJ-0
1) Remove all 4 color drum units, and close the front cover.
2) Select this item, and press the OK key to execute the operation. The operation stops automatically.
3) When automatic adjustment has finished, 'END' is displayed in the screen. Note The DC controller uses the photo diode in the laser unit to automatically measure the light quantity hence each laser emits its minimum light quantity. This operation is used to compensate the time the laser lights during minimum light quantity emission. Each laser unit Y/M/C/K) is adjusted in sequence.Comment
Well in that case I would installed the image reader and the hardware, cable for communication.
Afterwards go into service mode and change.
Copier>Option>Body> W/SCNR. Change it to 1.
See what happens.
Not to sure that this can be done, only because Canon had two different item codes for each model. You can purchase a Image Reader C1 for the IRc3220/2620, item code 7761A002AA.
Give it shot I think it might work.
Let us know.Comment
they also need to input the R-CON numbers in from behind side cover
COPIER>ADJUST>ADJ-XY>ADJ-X
COPIER>ADJUST>ADJ-XY>ADJ-Y
COPIER>ADJUST>ADJ-XY>ADJ-S
COPIER>ADJUST>CCD>W-PLT-X
COPIER>ADJUST>CCD>W-PLT-Y
COPIER>ADJUST>CCD>W-PLT-Z
COPIER>ADJUST>CCD>CLF-R-RG
COPIER>ADJUST>CCD>CLF-R-GB
COPIER>ADJUST>CCD>CL-R-RG
COPIER>ADJUST>CCD>CL-R-GB
COPIER>ADJUST>CCD>BW-R-RG
COPIER>ADJUST>CCD>BW-R-GB
COPIER>ADJUST>CCD>CCDU-RG
COPIER>ADJUST>CCD>CCDU-GB
COPIER>ADJUST>CCD>FCCDU-RG
COPIER>ADJUST>CCD>FCCDU-GB
RC5.JPGLast edited by teckat; 08-24-2010, 05:18 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
waste of time and effort to keep switching and installing a READER unit every time u need to calibrate .
Quick Adjustment: This is a quick and simple adjustment that is made to the gradation, density, and color settings of the machine. Re-calibrations are made internally without outputting any test prints.
In order to perform the Quick Adjustment :
1. Press the Additional Functions button.
2.Select Adjustment/Cleaning.
3.Choose Auto Gradation Adjustment.
4.Select the paper type for the gradation adjustment.
5. Press Quick Adjust.
6.Hit Start.
7.Press Done.
Note: The machine automatically adjusts the amount of toner and the speed of printing depending on the paper type selected.
simple is always easier'**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Color Calibration Utility CC-100 v2.61
Link for CC-100 V2.61-Software/Manual & Instructions_below
http://software.canon-europe.com/software/0026674.asp
NOTE
The Color Calibration Utility CC-100 supports the Color imageRUNNER series Base Printer model only. If you are using the Color imageRUNNER series Copier model, please use the printer's color calibration (Automatic Gradation Adjustment) function. The utility is not supported if the copier is connected to an imagePASS.
The Color imageRUNNER series requires an Ethernet interface and cannot accept a USB connection for the Color Calibration Utility CC-100. You should use only the scanner listed below. If you use other scanners, you may not be able to perform color calibration correctly.
Canon Color Calibration Utility CC-100 v2.6 adds support for Windows Vista. The Color Calibration Utility CC-100 has been designed to work with the following system environments:
Oerating Systems
- Microsoft Windows 98/Me
- Microsoft Windows 2000 Server/Professional
- Microsoft Windows XP Professional/Home Edition
- Microsoft Windows Vista
CPU - Intel Pentium CPU 100 MHz or higher
Memory - 32 MB or higher
Hard Disk Drive - At least 10 MB free space (while operating)
Interface - Ethernet
Compatible Printers
- Color imageRUNNER C5180 Base Printer model
- Color imageRUNNER C4580 Base Printer model
- Color imageRUNNER C4080 Base Printer model
- Color imageRUNNER C3220 Base Printer model
- Color imageRUNNER C3200 Base Printer model
- Color imageRUNNER C2620 Base Printer model
Compatible Scanners
- CanoScan LiDE60
- CanoScan LiDE70
Scanner Drivers
- TWAIN-compatible drivers, and WIA drivers with a TWAIN compatible mode
Canon Color Calibration Utility CC-100 Version 2.60US Supplemental Information
This product is a utility which enables stable outputs from color printers.
It is useful when the colors of the printout must be accurate or matched
between different units of the same model. By regularly calibrating the colors
of a printer, output results will not be affected by temperature and humidity,
or the particular characteristics of a printer.
System Requirements ------------------------------------------------------
The following systems and operating environments are recommended for this
utility:
Operating System
Microsoft Windows 98/Me English
Microsoft Windows 2000 Server/Professional English
Microsoft Windows XP Professional/Home Edition English
Microsoft Windows Vista Ultimate/Business/
Home Premium/Home Basic/Enterprise English
Hardware = A computer capable of running the software described
above
Printers = Canon Color imageRUNNER C5180
Canon Color imageRUNNER C4580
Canon Color imageRUNNER C4080
Canon Color imageRUNNER C3220
Canon Color imageRUNNER C3200
Canon Color imageRUNNER C2620
Scanner = CanoScan LiDE60/LiDE70
Caution --------------------------------------------------------------------
- For Windows 2000/XP, log on as Administrator when you start your computer.
- If you are using the Color Calibration Utility CC-100 for a printer on a local
connection, you cannot use NetSpot Suite Software ( NetSpot Job Monitor,
NetSpot Console). Close these applications and start the Color Calibration
Utility CC-100 after a moment. Also, do not print from other applications while
the Color Calibration Utility CC-100 is running.
- If the bidirectional support function of your printer is not set, you cannot
use this utility.
- If you are using Windows 98/Me, click [Spool Settings] in the [Details]
sheet of the printer properties dialog box, and confirm that [Enable
bidirectional support for this printer] is selected.
If you are using-
Windows 2000/XP/Vista, in the ports setting of the printer properties
dialog box, confirm that [Enable bidirectional support] is selected.
- If your printer uses an IPP connection (Internet Printing Protocol printer)
or SMB connection (Server Message Block), you cannot use the Color Calibration
Utility CC-100.
Last edited by teckat; 08-24-2010, 02:58 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
