canon ir 2545
  • mazen
    • 53
    canon ir 2545
    Hi ....
    my problem whith finsher of canon 2545
    when i was installed a finesher in copier due to the installation manual and start on copier
    the copier dont know with finsher
    thanks for any one help me
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Which finisher is it?
    Did you go over your connections?
    The finisher units come with instructions, all you have to do is follow.
      • 16083
      Originally posted by mazen
      Hi ....
      U TALKING ABOUT INNER FINISHER B-1
      check PM
      • charm5496
        • 2387
        It has to be the inner finisher B1, unless he has his model wrong.... check to see that you have the two connectors plugged in that are in the upper right hand corner of the machine just under the control panel.
        • mrfixit51
          Lead Service Technician
          • 1975
          Make sure copier is turned off when you add the finisher, and turn copier on after installation. The finisher should be recognized at that time. If not, some connector did not get seated.
          • charm5496
            • 2387
            Here are the installation instuctions
