I'm replacing some canon mfp. I need to remove the hard drive but don't know where they are located. The models are C587ou and 5000. Thanks.
Hard drives where are they located
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
iR5870 HDD
in back of printer
iR5000 HDD
use your imagination to locate on iR5000**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
For the iR5000 - remove the doc feeder, remove the rear reader cover, look to the top right. Unless you are going to trash the machine, I would look hard at what screws/plate need to be removed, and the power and data cable.
If you are looking to resell the units, would be better to clear the user data areas and settings (Canon has a TP on it) - that way you will not need to reload the system software and works for anything short of government requirements that say physically destroy the HDD.
BTW: formatting the HDD is kind of like locking a glass window.Comment
I'll give you positive rep. teckat. You were the first person to actually help this individual and not mock him. Something I've noticed too often here, people seek help and they get mocked for some reason. I bet that really makes their day. Kudos to you!
I don't know you at all but I agree. Sometimes some people get mocked instead of helped. Glad someone came through for you. Good luck. I'll give you a positive rep vote too for the trauma you've had to endure on this post.
YOU are quiet right. I suggest we nominate techat as the GLOBAL CANON TECHNICAL FIELD SUPERVISOR of the year 2010. His contribution to this forum is IMMENSE and has helped changed the lives of not only many technicians, but many canon machines users. He is highly knowledgeable and up-to-date in this field and ABOVE ALL NOT SELFISH with his knowledge, he shares it freely with other people. CANON MANUFACTURER should recognize and honour such people. MAY THE ALMIGHTY GOD BLESS YOU ALWAYS, teckat.Comment
