canon fax L-220
  • maks
    • May 2008
    • 75
    canon fax L-220
    we got this canon fax L-220 which always displays CHECK PAPER SIZE & RECEIVED IN MEMORY..ive cleaned the sensors(photo interrupter) but still get the same message.PLEASE ANY HELP??thanks in advance
  • montana
    • Aug 2008
    • 392
    hi...try to clear the memory go into service mode
    menu>#>clear data>memory clear
    i hope it's help...
    • maks
      • May 2008
      • 75
      thanks for answering Montana,if you wont mind?what or how can i get into service mode in canon fax machine?thanks again
      • aalex_bom
        • Jan 2008
        • 214
        i think y need replace pressure role! only one
        • maks
          • May 2008
          • 75
          our machine is working now from A4 size which has a problem i changed it to customised setting of small size ..
          • nhatthuc0000
            • Dec 2007
            • 44
            check PM and replace parts
            Good luck to you!
            • maks
              • May 2008
              • 75
              service mode of canon L295---function>data registration>#
