LBP5000 will not calibrate
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Gday all, I had been waiting on a LBP5000 fusing unit for over a month and it finally arrived today. Fitted it to the printer no problems there. However i can not get it to print correctly. Keeps giving "recalibrate" message. I really dont want to replace toner/drums or transfer belt as the costomer says it was all fine when the machine went down. Keep in mind this was over a month ago. I cant see how i may have created this problem just by replacing the fuser.
    If anyone has seen anything like this and can get me outta the crap here there will be few beers in it for them.
    Cheers,
    Jonezy.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
  • xman
    • Aug 2010
    • 48
    Having the same problem. I am not getting the recalibrate message but the black is out of calibration. Have recalibrated several times but no change.
    Have you solved your problem ?
    If so, can you shed some light for me.
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      yeh I got it sorted, but it was more bullshit than skill. what do your test prints look like?? can ya scan one for us??
      • xman
        • Aug 2010
        • 48
        LBP5000 will not calibrate.
        Its good to know you got yours sorted. Hopfully I attached this correctly. Attached are some test prints.
        Notice the shift in black on the windows icon and the black printed prices should be in the red circle.
        • jonezy999
          just one copy??
          • Feb 2010
          • 952
          It looks as if its shifting to the side, not like a ghosting, moving in the feed direction. Do you have the manual?
          • xman
            • Aug 2010
            • 48
            Yes I have a manual. My fault does seen like a calibration issue. What did you do to sort your calibration problem ?
            • jonezy999
              just one copy??
              • Feb 2010
              • 952
              just reseated everything and gave it a good clean out. Also adjusted something in service mode which I cant remember off the top of my head (at home now). Will get back to ya on monday with my notes.
              • xman
                • Aug 2010
                • 48
                I still have this machine here in the workshop. Any luck in remembering what you did to solve your calibration problem ?
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  It look like a image displacement issue. Give it a cleaning around the ITB, check the drums. You have a manual look for the Displacement Sensors. Check if there soiled.
                  Here is some more info.
                  1) Lack of calibration Forcibly execute calibration.
                  2) Failure in the ITB unit If the ITB does not rotate smoothly.
                  Replace the ITB unit.
                  3)If a cleaning failure (dirt on the ITB) occurred,
                  replace the ITB unit.
                  4) Wear/cut on the drive gear of the ITB motor
                  (Drum motor 3)
                  Check each drive gear between the ITB drive roller
                  and the ITB motor (Drum motor 3). If wear/cut is
                  found on the gear, replace the drive assembly.
                  5) Failure in the color displacement/density
                  sensor
                  Open and close the front door several times, and
                  clean the color displacement/density sensor. If
                  the failure cannot be removed, replace the color
                  6) Failure in the laser scanner unit Replace the laser scanner unit.
                  7) Failure in the cartridge Replace the cartridge of the color for which color
                  displacement occurred.
                  • spree
                    • Jun 2012
                    • 211
                    Re: LBP5000 will not calibrate
                    Please could you help?
                    I put out ITB, clean the senzors, put it back: it make 3 times calibration O.K., but than the calibration do not want to complete correctly. But the printer is printing very well - without out of registration.
                    I think I must replace the ITB.
                    Color displacement/density sensor is at the ITB?
                    • teckat
                      • 16083
                      A common problem with the HP1600, HP2600 and Canon LBP5000 series colour printers is cartridge alignment errors.
                      There are a few different things that cause this problem:
                      Dirty laser unit.
                      Faulty cartridges. This causes the calibration patches to be miss-read.
                      Transfer belt and sensors. Dirt/paper dust build up on belt and sensors may cause calibration patches to be miss-read.
                      Faulty engine control PCB. This seems to be a common cause for calibration errors and requires PCB replacement in the Canon series.
