Got a irc3200 (just copier), with Yellow seems to be out of alignment, the rest of the colours seem to be all good. just yellow. Anyone know how to get yellow back in?
irc 3200
Did u print out a PG6 test print Grid pattern ?
Is alignment issue on paper feed or cross-feed direction/ u need to look close at yellow.
if other colors a miss aligned, u could have a dirty underside of ITB sheet & the inside Lg. blk drive roller.
if only yellow color is miss aligned - Print out a P-Print with all machine settings ,Perform a DC con clear, turn off copier ,remove & re-cam yellow laser unit-Turn on copier and input all DC con values from the P-print output.
hope u have the manual or some experience on model**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
there is no reason to clear MN-CON for this issue/ that is poor information/
if the issue is only on one color as poster stated. u deal with the one color/ i have worked on hundreds of these models**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
teckat is correct on the MN-CON. All of your laser data is stored on the DC-CON and sometimes doing a clear on it will resolve your alignment issues. You may also have to retime the lasers by hand. That being said we need to see some samples in order to see what you are dealing with.Accidents don't just happen. They must be carelessly planned.Comment
