Canon IRC 3220 keep warming up after replace new magenta drum
  • tsann
    • Aug 2010
    • 11
    [Misc] Canon IRC 3220 keep warming up after replace new magenta drum
    My canon irc3220 keep warming up after replace new magenta drum, but put back the old drum it work ok...
    the den. for the magenta is -0.47% for old drum which work
    but for the new drum is -3.86%....what might be the issue here ? pls advice thanks
  • SCREWTAPE
    East Coast Imaging
    • 3396
    It might be a bad drum. I seen this before.
    • tsann
      • Aug 2010
      • 11
      i just change the drum to a new one and the problem come back after 4 day... a brand new drum
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Any errors in near past before this started.
        Other things can also cause isses like this.
        Fuser
        Main controller
        Dc
        • teckat
          • 16083
          like SCREWTAPE lists/ that fuser and it's connections can cause that issue
          see below>>>
          both those switches must actuate at the same time when fuser is pushed in & sensor must be cleaned out
          u need to check the Fuser unit & +++ that sensor/& switches below
          clean sensor/ + check ERROR Log
          these issues shown below can cause warming up issues
          • tsann
            • Aug 2010
            • 11
            i put back the old drum, it does not show warming up , but if put back the new drum the problem appear??? really confuse me...if it is the fuser or other part problem, it should be appear when i put back the old drum right.?
            • teckat
              • 16083
              fool the machine=
              put in old drum, close front door, wait until machine is ready, open front door, key up machine on door switch, & laser opening ,remove old drum, put in new drum, make sure that the laser is actuated ,run auto gradation,
              laser is actuated with post on document cover/ but u can do it manually
              see what happens
              • tsann
                • Aug 2010
                • 11
                thanks for the help. i tried but it is the same....i notice that the new drum after i put in the it will cover with the magenta tuner around the surface of the drum roller....some very rough toner... any idea why?...with the old working drum it does not have this
                • Van Steal
                  • 177
                  Faulty toner bottles can cause this fault to. Its not putting any toner in the new drum at setup.
                  • tinnyjay
                    • Oct 2009
                    • 663
                    If you installed old drum and copier works,it means new drum has a problem and you must use another one.
                    Maybe there is a factory defect of drum.
                    "Who loves the roses,must also bear thumbs"
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      That's not toner your feeling, that's developer.
                      The drum is the fault here. As I said, I've seen this many times.
                      Inspect the new drum with the old one and see if something is different.
                      • teckat
                        • 16083
                        Are these DRUMS Canon OEM or from some bootleg company/ what company do u buy DRUMS & Toner from
                        • tsann
                          • Aug 2010
                          • 11
                          i think it might be the toner issue.. after i took out the toner and put it back.. the new drum is working ...
                          • teckat
                            • 16083
                            check underside of toner cartridge sleeve / sleeve should move freely
                            /also-
                            imageRUNNER C3200
                            If the drum units have been removed repeatedly without the drum guide service tool it's possible to break one or both tabs (see picture below).These tabs open the toner hopper when the drum unit is slid in, and if they are broken, toner will not be fed into the drum unit.
                            **The unit may work for a while until the developer to toner ratio drops enough to cause an error.
                            • tsann
                              • Aug 2010
                              • 11
                              I notice that in the service mode, under copier, under DEN, the density for Magenta is between -2.00% to -4.00% , while the other color DEN is between -0.5% ~ -0.6%.... what do all this mean....my magenta drum still cause me problem...now it shows 02b0 error and after take out and put back several time it is ok again....why ?
