Canon iR 5570/6570 jam code 0102
  • skazic
    • Nov 2009
    • 25
    [Jamming] Canon iR 5570/6570 jam code 0102
    Hello, On several machines I got this paper jam. Paper late for PS28 sensor. I have replaced the role of vertical transport, sensor.
    Help please
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Inspect PS24 too.
    Check for wear and tear on the sensor flags.
    Inspect wiring for PS24 and PS28. Try removing tie wraps from the wiring.
    Make sure firmware is up to date as well.
    • skazic
      • Nov 2009
      • 25
      Hi
      I inspect all wiring, new firmware is up
      sometimes helps when I replace the plastic on the side door (black plastic with white plastic rolls)
      This problem is very frequent and very annoy
      • SCREWTAPE
        East Coast Imaging
        • 3396
        That part you change is not going to resolve anything.
        How are your pick up, feed, and separation rollers.
        When was the last time they were replaced.
        Try clutches on the pick up's, check the paper stock assy.
        Keep it simple man.
