Canon lms error
    replied
    Re: Canon lms error
    Originally posted by om_khatti
    ok
    thx to teckat skynet
    i got all answer
    now sugeste me fromwhere i buy and which kit i buy ??
    i not have more work for printing its very few job come here
    so i need afordable
    the PS kit will not function without UFRII/PCL kit
    To use the features of the PS Printer Kit, it must be Activated > after the optional UFR II/ PCL Printer Kit has
    been Activated.
    UFRII/PCL will function by itself.==========UFRII print driver is close to 2.5 times faster than either the PS or PCL drivers (hence the name Ultra Fast Rendering).
    take a chance on eBay/ combo complete license kit $ 425.74 US Dollar
    seller quotes > new & unopened /
    Ask Seller questions ( like where did u get all these combo kits from ) eBay now backs up all purchases )
    I have never seen both the UFRII/PCL & PS Kit combined by Canon
    Canon UFR II PCL PS Printer Kit S1 1355B002 AA | eBay
  • om_khatti
    replied
    Re: Canon lms error
    ok
    i got all answer
    so i need afordable
    replied
    Re: Canon lms error
    thx to all for suporte and guide me
    i have only serial number for this machine
    i think u all provide me good help but all is official way
    and i not have this 16 digit licence number
    any unoficial way for me for this machine ?
    You cannot print ethernet or usb to your machine as it is disabled until you buy a license.
    replied
    Re: Canon lms error
    for aditional information
    [ATTACH=CONFIG]28882[/ATTACH][ATTACH=CONFIG]28883[/ATTACH][ATTACH=CONFIG]28884[/ATTACH][ATTACH=CONFIG]28885[/ATTACH]
    now sugest me from where i start
    Network Scanning = To use this function, the machine is required to be connected to a network, equipped with the Printer function, and
    Network ScanGear to be installed on your computer.
    Send Function = Universal Send Kit must be Activated.
    Fax Function = Super G3 FAX Board or Super G3 Multi-Line FAX Board OPTION > Installed
    UFR II/PCL Printer Function and TIFF/JPEG Direct Print Function = UFR II/PCL Printer Kit must be Activated
    PS Printer Function and PDF/PS Direct Print Function = To use the features of the PS Printer Kit, it must be Activated > after the optional UFR II/ PCL Printer Kit has
    been Activated.
    Activated= means u need to spend some money to purchase the KITS that have the LMS License
  • om_khatti
    replied
    Re: Canon lms error
  • om_khatti
    replied
    Re: Canon lms error
    after more searching ur post i get some information
    plz check
    i see bootP now i need ur sugetion for this
    can i print with usb or lan ??
    need sugetion for driver
  • om_khatti
    replied
    Re: Canon lms error
    replied
    Re: Canon lms error
    i baught this machine refurbish condition i dont know where and what serial number for this kit
    how iknow serial number for this kit ?
    u should read the brochures on your products before a purchase (see attachment)
    they explain all options available
    u order single KITS from a Canon Authorized Dealership / ITEM CODES LISTED BELOW
    also believe there is a
    COMBO KIT available from Canon= UFR II / PCL / PS Printer Kit-S1 1355B002[AA] that has two LMS licenses
    i would not purchase online .
    BUYER BEWARE OF CHEAP or USED or NEW Statements
    a license can be transferred to a similar product < but it requires a transfer number from product & an original certificate LMS number.
    UFRII/PCL Printer Kit-S1 (LMS Activated)
    Optional controller enables networked printing with support for UFRII and PCL 5e/6 page description languages
    Item Code: 1354B001AA
    PS Printer Kit- S1(LMS Activated)_
    *Supports emulated PostScript 3 page description language
    * Requires the UFRII/PCL Printer Kit-S1
    Item Code: 1636B001AA
  • om_khatti
    replied
    Re: Canon lms error
    Originally posted by skynet
    Its a license key that activates the print function, its software, you cannot see it.
    replied
    Re: Canon lms error
    [ATTACH=CONFIG]28852[/ATTACH][ATTACH=CONFIG]28853[/ATTACH]
    i think now clear for me i not have any kit instaled ?
    on motherboard whare i chek ??
    any image for this kit ?
  • om_khatti
    replied
    Re: Canon lms error
    replied
    Re: Canon lms error
    its very good answer
    i got what i want
    happy with ur answer
    now i need 1st check machine that kit instaled or not
    but realy happy with ur suporte
    can i get location where this kit instaled in machine ??
    any image ?
    imageRUNNER 3025 / 3030 / 3035 / 3045 / 5055 / 5065 / 5075, imageRUNNER C2880 / C2880i / C3380 / C3380i / C4080 / C4080i / C4580 / C4580i / C5180 / C5180i / C5185 / C5185i, imagePRESS C1 / 7000
    ----Verifying that an LMS Based Printer Kit is Installed on an imageRUNNER / imagePRESS Device
    The Printer Kits for many of the newer Canon devices are LMS based.
    The BootROM on these devices will always end with a C. There is no N, P, or H BootROM for these devices.
    How to tell what Printer Kit is installed on these machines_!!!!!!!!!!!!!!!!!!!!!
    You can check for the LMS-based Printer Kit on the Canon device the same way as you would check for any other installed LMS-based option or kit.
    Perform the following steps:
    1. Press the [Counter Check] button on the copier control panel.
    2. Hit the [Device Configuration] button on the LCD screen.
    3. Scroll down through all of the available pages on this Device Configuration screen. Look for either PS, PCL or UFRII.
    The methods listed here (ex. PS, PCL, or UFRII) are installed and are available for printing.
    For example, if you find UFRII and PCL, but do not find PS on this screen on an iR C5180, it means that the UFRII/PCL Printer Kit is installed, but the PS Printer Kit is not installed.
    The exact Canon Printer Kits available vary by device model.
    See your specific device's documentation for more information.
    Print Options for the imageRUNNER 3045/3035/3030/3025===============;-/>
    These are the available print options and item codes:
    UFRII/PCL Printer Kit-S1(LMS Activated)
  • om_khatti
    replied
    Re: Canon lms error
    i got what i want
    any image ?
    replied
    Re: Canon lms error
    same problem for me
    i not able to print
    i am not technician
    my last problem with fuser film solved here so i come back here
    i need full guide for this process how activate printing through usb or networking
    what i need check before contact cannon
    step by step
    i ask my technician but unfortunatly he say this problem is out of his mind
    if possiblem provide me whole process
    IR3025
    PRINT WITH CONFIDENCE
    Activate the optional UFR II/PCL Printer Kit-S1UFR II Print Driver MENU
    Users who prefer PostScript workflows can add the optional PS Printer Kit-S1.
    Registering a LAN (License Access Number) on LMS (License Management System)
    The License Management System is a website used to register LANs (License Access Numbers) for Universal Send Kits and other optional kits for the Canon imageRUNNER devices.
    To Register a LAN:
    1. Using a Web Browser (ex. Internet Explorer) on your PC, go to the LMS website at
    http://www.canon.com/lms/ir.
    2. Enter in the LAN provided in the optional kit (ex. Universal Send Kit).
    3. Enter the serial number for the imageRUNNER device (the machine that the optional kit will be installed on). BE SURE TO ENTER THE CORRECT SERIAL NUMBER.
    4. Copy down the License Key number for the installation.
    For more information, please see the attached file lms.pdf.
    To Install the Optional Kit on the imageRUNNER Device:
    1. On the copier, hit Additional Functions > System Settings > scroll down > License Registration.
    2. Enter the License Key number you copied down when registering the LAN on the LMS website.
    3. Hit the Start button on the License Registration screen.
    4. Reboot the copier.
    * Note that some optional kits may require certain prerequisite items to be installed before performing the above steps.
  • om_khatti
    replied
    Re: Canon lms error
    same problem for me
    i not able to print
    i am not technician
    step by step
    IR3025
