More iR4570 problems
  • Pete Gossett
    • 45
    Well I thought everything was OK, after this problem I fought a couple weeks ago: http://www.copytechnet.com/forums/ca...-software.html
    It turns out that their other iR4570(the one I took the good HDD out of, and then installed the new one into) hasn't been able to print since then!
    It is online, it is scanning OK and the RUI comes up fine; however, if I try to Direct Print, there is a large exclamation point and the text "Cannot use the Direct Print function on this machine". I've tried different drivers from different PCs and XP/Win7/Server 08, with no difference. I'm sure this is all related, but what I'm not sure of is why???
    Any ideas?
    Thanks!
    Pete
  • teckat
    • 16083
    Any ideas?
    Thanks!
    Pete
    Direct Print from RUI -is available only with MULTI-PDL PRINTER KIT - E1 Installed
    • Pete Gossett
      • 45
      Doesn't the Multi-PDL kit E1 also allow network printing?
      • teckat
        • 16083
        Yes/
        • Pete Gossett
          • 45
          Hmm...well, Copier-> ACC-STS -> PDL-FNC1 has all-4 of the left bits set to "1"s, so it looks like that is OK.
          Any other suggestions?
          • teckat
            • 16083
            Stupid question > #1
            you do have the N Boot Rom installed from Multi Pdl Kit ?
            • Pete Gossett
              • 45
              Yes, N Boot Rom is in, and recognized in service mode.
              This copier was working perfectly fine until I took its HDD and Boot Rom and installed in it's twin iR4570 on the next floor(the one which wouldn't load system software onto the brand-new HDD). I then installed then new HDD into this iR4570(along with the Boot Rom from the other one), and successfully flashed it...or so I thought.
              I also tried reinstalling system software again yesterday. The copier accepted it fine, but it made no change. It really acts as though it doesn't recognize the Multi-PDL kit, although it shows it is installed according to your directions above.
              • teckat
                • 16083
                forget about RUI for now/ Can u print from your PC to the 4570 without using RUI ??
                • Pete Gossett
                  • 45
                  No, cannot print at all - scanning is fine though, and can access the RUI.
                  • teckat
                    • 16083
                    On your P Print this is what all your Vers .Should Read/except maybe for the Finishers
                    In SST u may need to RE-format the HDD/ then do select>single Boot >to update first/ then do an ALL
                    this series of models had a lot of issues in past with RUI/ that has already been addressed-
                    • mrfixit51
                      Lead Service Technician
                      • Oct 2008
                      • 1975
                      I would suggest that now that you have a working box that you reload the correct software, and set it to overwrite the existing software to make sure that all the files are fresh...
                      • kuby
                        • Oct 2007
                        • 1414
                        Could be something causing it not to print in the system software or switches of the machine. Had a problem with a ir5000 not wanting to print, after checking and reloading system software with no help, I finally did a MMI Clear and then after putting back in the IP address and the other setting, everything starting working. Have had to use the MMI clear a couple of times after that on other machine, always worked.
                        • CanonHPTech
                          • Apr 2007
                          • 235
                          Make sure your CA Key isn't corrupted. Check it under System Settings/Network Settings/TCP-IP Settings/Certificate Settings. If you don't have a green light or its not installed, you will not print. Have to generate a new key.
                          The glass maybe half full, but less is more...
                          Printer + Fax + Copier = Jack Of Many Trades,
                          but Master Of None
                          Color Copier = Not A Color Printer
                          InkJet MFP = Not A Fax Machine
                          B/W Copier = Not A Press
                          Finisher = Deal Closer (salesman, not accessory)
                          Copier Tech = Admin's Stress Ball (Scapegoat)
                          • teckat
                            • 16083
                            what key / certificate are u talking about ?
                            Multi-Pdl E1 Kit does not have a License Key Certificate for 4570
                            it included a N Boot Rom
                            Printer kits with boot rom-have no license
                            The Printer Kits for many of the newer Canon devices are LMS based. The Boot ROM on these devices will always end with a C.
                            • mrfixit51
                              • Oct 2008
                              • 1975
                              I believe he is referring to the CA-Key Clear in second level of Service Mode. That can become corrupted. He is not referring to a license key, as in the LMS system...
