More iR4570 problems
+ More Options
Posts
  • teckat
    • 16083
    #16
    Originally posted by mrfixit51
    I believe he is referring to the CA-Key Clear in second level of Service Mode. That can become corrupted. He is not referring to a license key, as in the LMS system...
    ok !!/ have seen that issue only with a message on control panel> Corrupt Key
    Generating a Key Pair and Server Certificate/ instructions below
    • Pete Gossett
      • 45
      #17
      Ah, well we might be on to something! I did have to generate a new key, as I was receiving a corrupt key error. The procedure seemed to work OK, and the message was gone afterward, but it did all start happening at the same time that printing apparently quit working.
      • teckat
        • 16083
        #18
        That Control Panel>Corrupt Key Message would have helped right from the start.
        Good luck on the Fix~~~~~~~~~~~~~~~~
        • Pete Gossett
          • 45
          #19
          Honestly, I'd forgotten about it, as it was over a week between fixing the other iR4570, and finally getting word that this one hadn't been printing the entire time.
          I just tried inputting another default key, but do I need to delete the old one first, or after I've created a new one?
          • teckat
            • 16083
            #20
            FIRST u can clear CA-KEY IN LEVEL 2
            1. Go to ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS>CERTIFICATE SETTINGS>
            2. Generate Key
            3. Key Name: Input CANON
            4. Select 1024 as the key length
            5. Input the current date as the start date
            6. Input an end date with current month and date settings but with the year listed as 2025
            7. Start Key Generation
            8. Go to Certificate Settings and select Key and Certificate List
            9. Highlight Default Key and press Erase
            10. Exit out of System Settings and Additional Functions.
            11. Cycle Main Power of copier.
            • Pete Gossett
              • 45
              #21
              Hmm...I was just looking at the settings for the working iR4570 through the RUI and noticed the Certificate settings show a certificate named CANON, but it is set to "Off" - yet it is printing fine????
              • Pete Gossett
                • 45
                #22
                OK, I followed steps 1-8 fine, but when I go back into the Key & Certificate list there is no Default Key, just the new CANON one I created.
                Do I need to set it as Default key, or do I erase it?
                • Pete Gossett
                  • 45
                  #23
                  OK tried it again. I cleared the Certificate in Level-2, then rebooted, then followed steps 1-8 and deleted the Default Key that had been created, then rebooted a 2nd time.
                  I still couldn't print, and Direct Print is still not available through the RUI.
                  So I went back into System Settings to the Certificates, and set the new CANON certificate as the default, then rebooted again.
                  Unfortunately, still no change - can't print from any PC, can't Direct Print from RUI.
                  • teckat
                    • 16083
                    #24
                    POST A COPY OF YOUR P-PRINT & USER DATA PRINT OUT SETTINGS from service mode
                    • Pete Gossett
                      • 45
                      #25
                      Here are the two pages from P-print I think you're looking for. I'll have to run the User Print next time I'm there.
                      • teckat
                        • 16083
                        #26
                        Everything looks OK !!
                        If the printer function is working correctly, the Configuration Page will be similar to
                        the sample below.
                        (Additional Functions).
                        [Report Settings].
                        [Printer] under <Print List>.
                        Press [PCL].Press [Configuration Page].
                        [Yes] to print the page.
                        • mrfixit51
                          Lead Service Technician
                          • Oct 2008
                          • 1975
                          #27
                          A reposting from 2 days ago...
                          "I would suggest that now that you have a working box that you reload the correct software, and set it to overwrite the existing software to make sure that all the files are fresh..."
                          I had a 5000dx that I updated recently, and lost the ability to print. I went back in, and reflashed the copier, choosing Overwrite All from lower left of the SST menu, and my printing capability returned. I feel that the system file must have gotten fubar'd on the first pass, and when I overwrote it, it repaired whatever got screwed up on my previous attempt.
                          • Pete Gossett
                            • 45
                            #28
                            Yes, I just did the Overwrite All today, using single files in Assist mode. Still didn't fix it unfortunately.
                            • teckat
                              • 16083
                              #29
                              This printer went from a Working Unit to a Brick ??
                              This all happened when u swapped out the Boot ROM & HDD to put in a 4570 non-working unit, the so called 4570 non- working unit now Functions with the other machines HDD & Boot Rom as a fully functional 4570 Network Printer.
                              Now the 4570 that used to function is the brick with the parts from other printer that did not function in the first place.
                              The common DENOMINATOR is either the BOOT ROM / HDD and or Main Controller
                              if Network boot rom it is damaged, you will need to contact the TSC (Canon) for the replacement procedure
                              Main Controller Pcb.
                              DC CONTROLLER
                              • Pete Gossett
                                • 45
                                #30
                                Sorry I've been so slow to update this, we took a loaner to the customer to buy us some time.
                                I finally got around to taking the Boot ROM from the broken iR4570 and installed in the unit still at the customer's - it worked fine. So I left it there, and brought this one back(which was the original Boot ROM from this copier) - no luck, still not printing and still no Direct Print.
                                I will try the HDD next week and report back.
