Matching user name with Equitrac ID
  • fryboy
    • May 2025
    Hi there,
    I need help here...
    I have been trying to integrate SAP printing with Equitrac.
    Here is what I have found out so far but unfortunately, I am still stuck.
    On SAP end, they are able to place the user name in the job title. (Please see attachment.)
    Hence, I thought of using EQXLPD to capture the user name and match it with Equitrac user ID. The user name and Equitrac user ID is different. However, I was told that only the owner properties, in this case SYSTEM, can be modified by EQXLPD.
    Next, I thought of adding the init string in the SAP print initialization, which will look like:
    # enter PJL mode and switch to PCL language
    \e%-12345X@PJL\r\n
    @PJL SET HOSTLOGINNAME="$(BENUTZER)"\r\n
    @PJL ENTER LANGUAGE=PCL\r\n
    # reset
    \eE
    In the Follow-You Printing, you can retrieve the user name from PJL setting HOSTLOGINNAME. However, this user name is different from the Equitrac user ID. So, I have no idea how to match it together.
    Of course, the clear way is to use LOCL but the organization needs to go through a print server and not by local printing.
    If anyone has any idea on workarounds to this issue, I am all ears and I need help desperately.
    Thank you.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    What model are you working on?
    • fryboy
      C5030
      • SCREWTAPE
        East Coast Imaging
        • 3396
        Vendor name...
        Canon
        Xerox
        ETC
        Which one??
        This is a Canon forum.
        • fryboy
          It is a Canon device.
          • teckat
            • 16083
            Call > Equitrac
            World Headquarters
            1000 South Pine Island Road
            Suite 900
            Plantation, FL 33324
            Tel: 1.954.888.7800
            Fax: 1.954.475.7295
            Fax: 1.954.697.2323 (Sales)
            Toll free: 1.800.327.0183
            European Offices
            Equitrac UK Ltd.
            1st Floor, CentralPoint
            45 Beech Street
            London, EC2Y 8AD
            Tel: + 44 (0)207 072 0970
            Equitrac Netherlands
            Teleport Towers
            Kingsfordweg 151
            Amsterdam, 1043 GR
            Tel: + 31 (0)20 586 4300
            Software Development
            450 Phillip Street
            Waterloo, ON N2L 5J2
            Canada
            Tel: 1.519.885.2458
            Fax: 1.519.746.7931
            Toll free: 1.877.378.4872
            • fryboy
              I tried but they are unable to give me a workaround.
              • teckat
                • 16083
                CHECK THIS WEB SITE
                SAP Community Network Forums: Sending Userid when printing job from ...
                • fryboy
                  I have seen this website but it did not tell me a solution because the SAP user id is different from the Equitrac ID.
                  • teckat
                    • 16083
                    Equitrac is usually helpful / if they have no answer -Call a reliable Canon service trained tech
