IR330 keeps blowing exposure lamp
  • mitchl
    • Apr 2007
    • 501
    Got an IR330 that keeps blowing its exposure lamp, replaced DC controller, power supply and of course numerous lamps......... what are we missing here? Any help would be appreciated.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Cooling fans running?
    • mitchl
      • Apr 2007
      • 501
      Dont know but will ask the tech now........ thanks!
      • teckat
        • 16083
        imageRUNNER 330 / 400 Premature Scanning Lamp Failure
        Check the pins for connector J90 where it plugs into the rear frame of the machine for a bent pin (see photo; note the screwdriver which indicates J90). If one pin is bent, the scanning lamp will still light however it will fatigue quickly and fail. Observe the lamps that have been replaced to see if they are darkening on only one side of the lamp. Replacing the harness FF3-2993-000 or reforming the bent pin will repair the problem.
        • andy21557
          Help Desk Technician
          • Jul 2009
          • 62
          i myself had that pin bent i was replacing the lamp about every 2 weeks
          • Peter Sim
            • Sep 2008
            • 445
            -Ones you change the composite power supply you need to reenter the service label value into the service mode adjustment.
            -You must execute shading auto correction after you replace the scanning lamp>Function>MAN-ADJ.(follow the service manual procedure)
            • mitchl
              • Apr 2007
              • 501
              do you mean fan fm9?
              • mrfixit51
                • Oct 2008
                • 1975
                FM12 & FM13 are the optics cooling fans...
                • mitchl
                  • Apr 2007
                  • 501
                  thanks i will check FM12 & FM13 fans....
                  • teckat
                    • 16083
                    ??-if a fan is not working, there should be an error code present/ especially cooling fans
                    • mrfixit51
                      • Oct 2008
                      • 1975
                      That is true enough, but that only checks for the fan being there running, not if there is a clogged vent in the cover that it servicing those fans...
                      I too like the bent pin as the culprit, but offered this as a possibility for overheating the lamp??
                      • teckat
                        • 16083
                        see what u mean/ had CLC 4000/5100 fan issues when some techs pushed those mesh filters into fan blades when putting back covers
                        • mitchl
                          • Apr 2007
                          • 501
                          I went out to the job site and the fans FM12 & FM13 are comming on.... And connector J90 has no bent pins....
                          • mrfixit51
                            • Oct 2008
                            • 1975
                            This just occurred to me,,, how about replacing the scan lamp cable itself? It flex's back and forth for every scan, possible broken wire in that would give same results as bent pin issue...
                            • teckat
                              • 16083
                              This is from year 2000
                              imageRUNNER 330/400
                              Short life of the scan lamp or the error code E803 indication occurs.
                              Due to improper adjustments made at the factory, on some machines, the preheating
                              voltage was lowered, which resulted in the short life of the scan lamp. The correct factory
                              procedure calls for adjusting the preheating voltage after the FLOFST value was input, but
                              the preheating voltage was adjusted before the FLOFST value was input on some
                              machines.
                              Please make sure your Power Supply Values are entered into Service Mode correctly if the
                              Composite Power Supply has been replaced.
                              We would like you to change the FLDUTY/FLPDUTY from the LAMP values. The
                              machines that may possibly cause this are set 127 or less as the FLOFST.
                              Therefore, in case the affected machines are already set 127 or less as the FLOFST, enter
                              60 as the FLDUTY and 55 as the FLPDUTY.
                              Machines Affected:
                              NQH: 00001 to 00948
                              NQG: 00001 to 14847
                              NQK: 00001 to 00066
                              NQJ: 00001 to 24804
