ImagePRESS C-1 code E00014 - 0002
  • COCODIAZ
    • May 2010
    • 31
    [Error Code] ImagePRESS C-1 code E00014 - 0002
    Hi, can help please
    i got this code refer to fixation motor, can anybody tell me what have to do
    trnaks in advance
    coco
  • teckat
    • 16092
    Originally posted by COCODIAZ
    Hi, can help please
    trnaks in advance
    coco
    Check Pressure Belt in the Fixing Assembly.
    were u working on fixin unit before code ?
    imagePRESS C1 E014-0002 from Fixing Assembly.
    inspect the Fixing Belt Assembly, check that connector J814 which is located on the Fixing Belt drive Motor M36is seated all the way. This connection does not have to be removed when taking out the Fixing Belt Assembly. When removing the other connectors from the Fixing Driver PCB, the wire harness is pulled and the connector J814 could be dislodged accidentally. Re-seat the connector J814 on M36 Motor Driver to maybe resolve error
    • COCODIAZ
      • May 2010
      • 31
      I inspect the fixing belt assembly, (can send me pics (diagram)of the connectors j814 and M36 motor dirive) ond dont work
      help me please
      coco
      • "Harvey Dent"
        Something is preventing the movement of the fixing motor. When was the last time it was rebuilt?
        • teckat
          • 16092
          help me please
          coco
          Picture is shown / use scroll bar below to view full pic
          • COCODIAZ
            • May 2010
            • 31
            I check the fixing motor and found the cleaning web jam with the fixing roller, can u send me a diagram of the correct postion of the cleaning web
            thanks in advance
            • teckat
              • 16092
              thanks in advance
              Look at Picture to see how Web position is seated
              Make sure web detection arm sits right//u can better see position on top picture
              • "Harvey Dent"
                Nice pictures.
                • teckat
                  • 16092
                  • COCODIAZ
                    • May 2010
                    • 31
                    Thanks for the pictures, was very useful.
                    now i reasembly all ok , but have a code : e0001 - 004, can help me please
                    • teckat
                      • 16092
                      Outside heating
                      roller
                      Main thermistor THM5 (roller center; contact)
                      Sub thermistor THM6 (roller rear end; contact)
                      Check connectors & contact position of thermistor -THM6 & 5
                      E001 =High
                      temperature
                      detection error
                      0004 -Indicates the outside heating roller edge high
                      temperature detection error. (220 deg C;
                      Hardware detection)
                      Recovery method=go into>Reset in service mode:
                      COPIER>FUNCTION>CLEAR>ERR
                      ERR (Target error codes: E000/E001/E002/E003/E005)
                      Operation method
                      1) Select this item and press the OK key.
                      2) Turn OFF/ON the main power.
                      FUNCTION>CLEAR>ERR
