Imagepress c1 - fuser roll
  • COCODIAZ
    • May 2010
    • 31
    [Misc] Imagepress c1 - fuser roll
  • teckat
    • 16083
    Quick ?? are u trained on any of the Models u request help for/ & do u have the service manuals
    if you have never done this procedure, I would call a tech who has done this, u can break heater connectors very easily
    Pull out the fixing/feeding unit toward you
    Remove the fixing main heater/fixing sub heater.
    Remove the fixing roller
    - 2 C-rings
    - 2 gears
    - 2 bearings
    - 2 fixing roller heat insulating bushes
    - 1 holder
    When Mounting the Fixing
    Roller
    - The orientation for mounting the gears and the
    heat-insulating bushes is specified. Mount
    them in the orientation shown in the below figure.
    Make sure to wipe off the excessive grease because
    the grease adheres to the both edge [1] of the
    fixing roller when mounting the greased bushes to
    the fixing roller
    When replacing the fixing roller / the fixing belt, or
    both of them, be sure to clean the surface of the
    fixing roller and the fixing belt with a lint-free paper
    FL3-0893-000=ROLLER, FIXING
    also on outside of FIX UNIT u need to replace w/new 73T GEAR FU6-0609-010
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      Good work teckat.Also you must to replace refresh roller,manual feed and separation roller,fixing cleaning belt and roller FC7-0169
      • teckat
        • 16083
        good point, best bet is for poster to get some experienced tech in there
        • zoraldinho
          • Mar 2008
          • 5007
          agree.
          • teckat
            • 16083
            Originally posted by zoraldinho
            agree.
            when this model first came out, in Canon Training School , experienced techs were breaking those heater contacts
            while trying to do this removal for first time
