iRC ADV ISSUES
  • Gerhard
    • Oct 2009
    • 99
    iRC ADV ISSUES
    Hi All
    I have a ir 5030i adv giving me the following issues. The mailbox names dissapear twice a week , but a reboot fixes that and you need to manualy delete mailbox content after printing the documents. Firmware is latest.
    All welcome
    sigpic
    Life is a Journey enjoy the ride !!!
  • teckat
    • 16083
    Originally posted by Gerhard
    Hi All
    All welcome
    To set Auto Delete from mailbox on the imageRUNNER ADVANCE Series
    1) Select Settings/Registration on the copier's display.
    2) Select [Login].
    3) Enter the System Manager's ID as well as the System Pin.
    4) Select [login].
    5) Select [Function Settings].
    6) Select [Store/Access Files].
    7) Select [Mail Box Settings].
    8) Select [Settings for All Mailbox].
    9) Select [Time Until File Auto Delete].
    You have the option to choose from hours to days.
    Set from 0=Off 1, 2, 3, 6, 12hrs to 1, 2, 3, 7, 30days.
    10) Select OK.
    NOTE: The time interval you choose will be pushed out to each mailbox. If you return to this menu item it will revert back to the default of 3 days. However, this is only the display setting here, the individual mailboxes will reflect the correct time interval that you have established.
    you think someone is deleting names by mistake ??
    you can assign a pin# to prevent deletion>
    Highlight a mailbox number, then click in the Registered Box Name field, the keyboard will appear.
    Type in the name for the mailbox, press OK.
    If you want a password, enter a PIN and press OK
    • SCREWTAPE
      East Coast Imaging
      • 3396
      If names are disappearing.
      I don't know, but as teckat mention. Somebody might be playing around.
      I would also reload firmware. At least you can eliminate the possibility that firmware can be the issue.
      • Gerhard
        • Oct 2009
        • 99
        Hi All
        The deleting of print jobs should be instantanous after a user has printed a spicific print job as per Ir 3025 etc. I understand the way teckat explaines, but that is for print jobs that remains in the mailbox for x period of time.
        The mailbox names is a weird one. The mailboxes are programed and setup correctly, but they just dissapear for no reason and return after reboot. Firmware is up to date.
        Thanx for input
        Regards
        sigpic
        • Canuck
          Tech Specialist
          • 1713
          Just FYI...Make sure that you are using latest version of Service Support Tool to install the latest firmware. Earlier versions of SST had problems of not updating the DCon
          • Fer
            • Nov 2009
            • 267
            Can the Advance replicate mailbox names from other advance machines? I don;t have documentation at hand here but i remember i can for the adressbook.
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Yea, you can export the address book, then import the address book to the other machine.
              • Fer
                • Nov 2009
                • 267
                I don't mean export/import trough the rui. But automatic syncing the adressbooks by using the automatic discovery on the network.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  LDAP protocol could be a good way. LDAP protocol is used to browse on a server running LDAP. It can retrieve contents of the address book resident on that server.
                  You also have imageWARE Enterprise Management Console. This plug-in enables you to deliver address books to devices connected to the network. You can also retrieve address books from devices connected to the network.
                  For the Advance models. There is Remote Address Book. The Remote Address Book is only available on the imageRUNNER ADVANCE models. I haven't played around with it yet.
                  • Gerhard
                    • Oct 2009
                    • 99
                    Update
                    Remedy is involved. Good to know i am not the only one with mailbox problems. The deleting problem was solved with RTFM.
                    Thanx all
                    Regards
                    Gerhard
                    sigpic
                    • teckat
                      • 16083
                      Update
                      Thanx all
                      Regards
                      Gerhard
                      RTFM ?
                      {Read the F@#%^*+! Manual}
                      • mrfixit51
                        Lead Service Technician
                        • Oct 2008
                        • 1975
                        Update
                        Thanx all
                        Regards
                        Gerhard
                        Hi Gerhard,
                        What was the resolution for your "Mailboxes names are disapearing" problem. I now have a call in my queue with the same description. When they try to access mailboxes, the names are gone, when they turn off the copier and back on, the mailbox names are back... I am interested in what resolved that problem for you!
                        • Canuck
                          Tech Specialist
                          • 1713
                          Flaky machines...had one today,slow to change screens(5 secs),print,re-boot didn't fix. Had to shut down,unplug power cord for 15 sec,then restart.
                          • SCREWTAPE
                            East Coast Imaging
                            • 3396
                            I agree, there's that delay once in awhile.
                            • herlin
                              • Jan 2011
                              • 33
                              dissapearing mailboxnames solved?
                              Have exactly the same problem with an ir-adv6000. Are there any solutions yet?
