Help Setup IR2200
  • russellwrx
    Help Setup IR2200
    Hello
    I'm trying to setup IR2200 as a printer in our office. It doesnt have network card, but has standard printer port. I'm using windows 2000 server with PCL5/6 drivers installed. When I'm trying to print printer makes initial noise "data" indicator flashes, but nothing happens. I have checked all settings, logs do not register printer job no error nothing. Please help
  • Copier_Guy
    • 543
    Originally posted by russellwrx
    Hello
    When you set up this printer, use the PCL5 driver. The PCL6 has been known to cause problems. Are you setting this up as a Network Share? Or are you using a network print adaptor or print server?
    Let us know.
    • russellwrx
      Thank you your reply. I have tried PCL5 driver with the same result. Printer currently connected directly to the printer port on the server. I tried different printer port setting Standatd->ECP etc. without any success, I even tried to use USB to printer cable, results are the same. In system monitor it says it's receiving print under IPX
      • Copier_Guy
        • 543
        Are you using Netware? Also, being connected directly to the server, do you have the print driver loaded on each individual host?
        • russellwrx
          sorry not IPX network RX. There is no nework card in the printer.
          • Copier_Guy
            • 543
            I'm not exactly sure what network rx is, but I forgot to ask you an obvious question. Is this machine a printer or copier. You can check that by going into level 1 service mode and checking the bootrom version. If the version is followed by a C, your machine is a copier and it won't print. If it's followed by an N, it's a printer and we can go on.
            • russellwrx
              Thank you I will check it up tomorrow, I presume it's a printer as there are some print job logs there from 2004. Is it possible that bootrom has been changed to copier only?
              • Copier_Guy
                • 543
                Copy jobs show up in the print job log also. I'm thinking it's a copier because the printer kit comes with a NIC. The 2200N model also comes with a NIC.
