card reader
  • alex@wocltd.com
    • 430
    card reader
    hi people - have a card reader d1 to install on 5151/5185 (whatever you wanna call it) I know how to fit it I just dont know how to program the cards and can't find any info anywhere I have two sets of cards(i presume 1 master set and the other for all users)
    any help? thanks
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5006
    any help? thanks
    The card reader is installed in a way suited to its host machine. See the Service Manual of
    the respective host machine.
    • alex@wocltd.com
      • 430
      • teckat
        • 16083
        any help? thanks
        iR5185
        Select: COPIER > FUNCTION > INSTALL > CARD, and then enter a
        given number from 1 to 2001 (first number of the customer's user card)
        Press [Reset] to exit from the service mode.
        Turn OFF the power supply following the shut-down sequence.
        Turn On the main power switch.
        COPIER>FUNCTION>INSTALL>CARD
        Used to make card reader installation settings.
        Setting values
        1 to 2001 [Factory default/After RAM clear: 1]
        Operation method Enter the number of cards to use. (You can use up to 1,000 cards from the entered number.)
        Initialize the card management information.
        - Initialize the card name (department ID) (from the entered number).
        - Initialize the card's password.
        When attaching the card reader, be sure to attach it with its label indicating
        the direction to insert the card on the surface.
        • alex@wocltd.com
          • 430
          thanks bud! have a beer on me!
          • teckat
            • 16083
            Thanks for the offer'
            • zoraldinho
              • Mar 2008
              • 5006
              Ha ha.Teckat you are fanny gay.
