Help me please Canon IR6800c XP SP3 (32bit) driver USB problem
  • bojanbelgrade
    • Aug 2025
    my model canon IR6800C dadf -m1 no:1000006924 canot connect for usb port.that driver is download and install for my canon ir6800c windows xp 32bit sp3.please send me link to download compatible driver for my model and name driver ?
    UFR_v1.51_Setup.exe not work for canon site.
    Tell me step by step how to instal corect driver in USB port not UTP.
    thanks
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Does this copier have a printer kit?
    • bojanbelgrade
      no
      • Herrmann
        • Jan 2006
        • 792
        without a printer kit, this unit will not print at all
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • teckat
          • 16083
          thanks
          The IR6800C is available in two versions. The IR6800CN comes fully network ready with a built-in PS/PCL/UFR printer board, for people who want colour control. The IR6800C is available with an EFI- postscript printer board D1, for true PostScript giving greater colour control.
          Colour Network Printer Unit-D1 (Standard for iR 6800C)
          PDL Adobe PostScript 3, PCL 5c
          Resolution 2400 equivalent x 600dpi
          Memory 128MB to 256MB(Optional)
          Hard Disk 20GB
          CPU Intel Mobile PentiumIII 850MHz
          PS Fonts Roman138
          PCL Fonts Roman78 (including Barcode Fonts)
          Supported OS
          PS Windows 98/ME/NT4.0/2000/XP/2003,
          Mac OS9.0/X
          PCL Windows 95/98/ME/NT4.0/2000/XP/2003
          Interface IEEE1284, Ethernet(100Base-TX,10Base-T)
          Network Protocol TCP/IP(LPD/FTP/Port9100/IPP/SMB/email),
          IPX/SPX(NDS, Bindery, NDPS-GW), AppleTalk
          Colour Universal Send Kit-C1 (Optional)
          Sending Function (optional)*
          *The optional Color Universal Send Kit and
          Resolution Switching Board are required.
          You can upgrade this machine to a
          high-speed network printer by installing the
          optional Color Network Multi-PDL Printer
          Kit. This kit incorporates UFR (Ultra Fast
          Rendering) Technology
          • SCREWTAPE
            East Coast Imaging
            • 3396
            no
            Then how are you expecting for this machine to print.
            • bojanbelgrade
              My 1 machine IR6800c is connect for USB port but not work---print document file (and this I will somehow make)
              My 2 machine IR5050 is connect for USB port and print fine for driver UFR.
              My 1 machine is ir6800c not ir6800cn(n-network) model is ir6800c I understand but not understand why is not connect for USB port? USB. i connect usb cable to notebook and windows add new hardware but not work.
              My 2 machine is connect for USB port(unnecessarily) and UTP(cross-ower)-cable ,config for IR5050 IP 192.168.1.2; SM 255.255.255.0; GATEWAY 192.168.1.1 config for my notebook network card is IP 192.168.1.1 ;SM 255.255.255.0 : GATEWAY 192.168.1.2 and work fine but i have problem how to download file for IR5050 Hard-disk to my notebook hard-disk. OK,, how to send save file in ir5050 to notebook.
              My 2 machine IR5050 works all type connection (UTP-TCP/IP) and USB...only 1 problem is send file ir5050 to notebook.
              My 1 machine ir6800c not work (UTP-TCP/IP) and not work for USB port.(not possible any connection)
              • teckat
                • 16083
                My 2 machine is connect for usb and UTP(cross-ower)cable ,config for IR5050 IP 192.168.1.2; SM 255.255.255.0; GATEWAY 192.168.1.1 config for my notebook network card is IP 192.168.1.1 ;SM 255.255.255.0 : GATEWAY 192.168.1.2 and work fine but i have problem how to download file for IR5050 Hard-disk to my notebook hard-disk. OK,, how to send save file in ir5050 to notebook.
                imageRUNNER C6800 / 5800
                type of documents that can be Sent from a User Inbox:
                Documents that can be sent from a User Inbox are:
                • Documents sent from the Send Screen to a User Inbox
                • Documents received and stored in the Memory RX Inbox
                Note:
                Documents that cannot be sent from a User Inbox are:
                • Documents scanned ans stored in a User Inbox via the Mailbox function
                • Documents of print jobs that are sent from a computer
                imageRUNNER C6800
                Location of the USB or Token Ring PCB's installed on the imageRUNNER C6800
                Either the Token Ring Network Interface Adapter iN-TR 2 (6910A001AA)
                or the USB I/F Board-A3 (8349A003AA) can be installed in slot J1104 on the Main Controller Board. Only one board can be installed in the machine at a time, not both. The Token Ring Network Interface Adapter iN-TR 2 Installation Procedure indicates the use of a Riser PCB. Disregard the procedure and install the Token Ring board into the connector J1104.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  You need a printer kit in order to print.
                  Just because there is a port for a connection, does not mean the machine is a printer.
                  • bojanbelgrade
                    ok i buy printer kit for ir6800c.
                    Thanks all
                    • teckat
                      • 16083
                      no
                      The USB Interface Board can be used only if the optional Color Network Multi-PDL
                      Printer Kit is installed, or if the Super G3 FAX Board and Resolution Switching Board are
                      installed.
                      • To connect your computer and the machine with a USB cable, you must install a USB
                      Interface Board with a Color Network Multi-PDL Printer Kit to use the printer functions,
                      You cannot use the Network Scan function from the computer connected to the machine
                      through a USB connection.
                      • bojanbelgrade
                        Of course I know
                        I did not know
                        but we did not understand why is the rear entrance USB if not in use or why there is input USB if not in use.
                        all in all i contact my dealer for buy a Printer Kit
                        • teckat
                          • 16083
                          Of course I know
                          I did not know
                          The UFR Pcb.Board is included in the Colour Network Printer Unit-D1
                          Did u open back of printer to see if USB IFPCB is installed properly/ u still need the Color Network Multi-PDL Printer Kit in stalled for it to function
                          • bojanbelgrade
                            J1104 USB or token ring board: YES inserted in the slot
                            J1106 Network Interface Card:Yes inserted in the slot
                            Now nothing I do not understand what is happening
                            Ok man i call my dealer to repair and conection IR6800c to my notebook.
                            something is wrong here J1104 USB or token ring board inserted in the slot and J1106 Network Interface Card inserted in the slot but not work.
                            Ir5050 (UTP-TCP/IP and USB connect) work fine
                            Ir6800c (UTP-TCP/IP and USB connect) not work
                            • teckat
                              • 16083
                              YOU NEED THE UFR Pcb installed in J1105 (it is in the Printer kit D1) for USB Functions
                              READ BELOW>>>>
