Help me please Canon IR6800c XP SP3 (32bit) driver USB problem
  • bojanbelgrade
    #16
    J1104 USB or token ring board: YES inserted in the slot
    J1105 UFR OR OPEN I/F BOARD - inserted in the slot man YES
    J1106 Network Interface Card:Yes inserted in the slot
    ok look J1106 Network Interface Card inserted in the slot why is not connect for netwrok card? or tell me link to download USB class driver for xp sp3 32bit pro and i testing machine now.
    I still think that the incorrect machine
    • bojanbelgrade
      #17
      i connect usb to notebook turn on machine and how to recognize new hardware Canon IR6800c my OS XP Pro if not all the cards? ok how? tell me??
      I am not a genius but wash to install ordinary drivers for any printer or any models over USB port.
      All drivers from list http://software.canon-europe.com/products/0010039.asp i testing and not work for model Canon IR6800c
      All drivers from list http://software.canon-europe.com/products/0010056.asp i testing and not work for model Canon IR6800c ,,,and if it is not my model but I tried.. this is for model Canon IR6800c-d1 and not work.
      Not work in network not work USB port connection, not work any.
      Model Canon IR5050 work all manual or connecting for PC, model 6800c work manual but connect for pc nothing.
      I still think that the incorrect machine and i call my dealer in monday 7.00PM a and break the machine of his head.
      • teckat
        • 16083
        #18
        Model: UFR Rendering Board (SURF Board): UFR Printing Support? imageRUNNER C3200/C3220/C2620 SURF board included with Color Printer Kit A1/A2. Only with Color Printer Kit A1/A2 installed. imageRUNNER C3100 SURF board is standard. Standard. imageRUNNER C3100N SURF board is standard. Standard. imageRUNNER C5800/C6800 SURF board included with Color Printer Kit C1 Only with Color Printer Kit C1 installed.
        * This Rendering board (SURF board) is REQUIRED to print via UFR.
        Models supported: imageRUNNER C2620 / C3200 / C3220, imageRUNNER C3100 / C3100N, and imageRUNNER C5800 / C6800.
        * Note - UFR printing is NOT supported with the imagePASS or ColorPASS controllers.
        The Open Interface Board (used for the imagePASS controller's connection to the copier) gets installed in the slot where the SURF board belongs. The SURF board must be removed from the copier to install the imagePASS controller.
        * UFRII printing is not available when a Fiery controller (ex. imagePASS, ColorPASS, imagePRESS Server) is connected to the Canon device.
        UFRII Print Drivers for the supported Operating Systems are available for download on the e-support site in the Download Center.
        • teckat
          • 16083
          #19
          NIC Card is for your Network connection
          An IF Pcb (J1105) is for a connection to an external imagePass Fiery Server
          Th UFR pcb.(J1105)is used when u do not have a Fiery Connected
          so u must have the UFR Pcb in that slot J1105
          OK ! so that means u do have the Color Printer Kit C1 installed
          u now need to Check in service mode to see see if your Copier > Option > Int-Face > IMG-CONT is set to "0"
          • bojanbelgrade
            #20
            tomorrow comes the dealer to look at the machine and bring what he did.
            Thanks all
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5007
              #21
              • bojanbelgrade
                #22
                nema potreba za stvarima oko ovih suvisnih informacija operativne sisteme poznajem odlicno,microsoft sam prostudirao sve njihove gluposti, radne grupe,domene,prava pristupa,serveri,stanice gomila glupog softwera sve su to gluposti za 16-godisnjake.Meni ne trebaju glupi komentari sa tutorijala canon-a koje sam procitao npr. pod 1 nema potrebe za pristup hardu ir5050 preko glupih mail funkcija mailbox-ova hehehe itd itd kad se to odradi za 2 sekunde preko ip adrese a to cu da dokazem vrlo brzo mada nema potrebe.pod 2 ako ja ukljucim usb u moj notebook i ako ga win xp OS prepozna za 5 sekundi i kaze new hardware canon ir6800c kakvi bre kit-ovi i gluposti i dali ima kartice u slotove,pa naravno da ima gde bi ga ukljucio u guzicu!!! i kako ga windows prepoznaje preko teleportacije ili preko kitova ili bolje reci kite, za mene postoje samo ploca, kartice,procesor,memorija,harddisk i firmware koji necu da diram da mi dileri nebi garanciju ponistili sto i cekaju inace bi i to odradio.
                svi oni ovde ceo zivot rade ovo i ne mogu da rese problem jednostavno.
                Iskreno ja ti ovo proucavam 2 dana i 12 sati.
                Napravicu ja to druze kao i sve do sad sto sam napravio,nema toga sto se ne moze, sjutra kad diler dodje sa svojim serviserima i vidi da ne moze to ide kod njihovih dilera a ako se ne varam zavrsava kod vas u Ljubljanu a kad vam stigne kod vas vi probajte promenite plocu ubacite nove kartice i napravicete ga ovako ne sigurno i nece vam trebati kit nikakav,ako ne uspete taj uredjaj ide kod ovih ljudi
                Admin Address........ Ohta-ku
                Admin Address........ 146-8501
                Admin Address........ Tokyo
                Admin Address........ JAPAN
                Admin Email.......... @WEB.CANON.CO.JP
                Admin Phone.......... +81.337582111
                Admin Fax............ +81.354827404
                ako ti trebaju i od Obame podaci JAVI
                pozdrav
                • Fer
                  • Nov 2009
                  • 267
                  #23
                  The only way to this machine without a printerkit, is using the little with box on the back. The imagepass/colorpass print controller. It should be connected to the copier with a short network cable and scsi cable (i'm sorry open interface cable). U should connect your laptop to the print controller using a crosscable.
                  In service mode make sure the print controller is enable in Copier,Option,ext-interface, setting the controller on 3. cycle power (machine off/on). U can set the ip now under, printer tab.
                  Good luck
                  • bojanbelgrade
                    #24
                    jedini pametan covek ovde je fer objasnio mi je da mi treba cross-ower kabal i proceduru koju sam probao i nije uspelo,bar 20 puta sam ovo probao jer sam tako spojio 5050 bez problema.isto tako pitam sve ljude sa nasih prostora neka mi nadju neki uredjaj na celom svetu a napomenuo sam bukvalno 100x da sam povezao preko USB-a na notebook sa xp 32bit OS-om i da je masinu Canon IR6800C XP prepoznao kao novi hardwer oznaku ir6800c dodao drajver kompatibilan i nista od toga.E sad postavljam pitanje nasim ljudima koji budu citali ovu temu mozda ce im nekad trebati "nedaj boze ali za svaki slucaj"dali je moguce da neki uredjaj prepozna kad se poveze preko usb-a "bilo koji uredjaj" a da tom uredjaju treba dodatak,kit ili bilo sta mozete cak i naucnu fantastiku da koristite u razmisljanju voleo bi da znam jesam li ga povezao u guzicu ili na notebook-ovu mreznu karticu i dali mi je prepoznao novi hardwer guzicu kao ir6800c ili kopir masinu nemam pojma kako izgleda usb pa sam promasio sigurno na ir6800c a na 5050 pogodio, eto samo me to zanima naucnici dali mi treba kit ako ima ulaz USB u njega i kad se spoji sa NOTEBOOK-om bilo koji OS on ga prepozna kao novi hardwer ili je problem druge prirode.a svima cu da kazem da sam napravio jer ovo pocinje da me nervira vise.
                    Samo jedan pametan covek mi je na mail rekao da pristupim hard disku direktno svi ostali koriste mailbox podesavanja da bi to uradili.
                    Fer man good job I made everything and now everything is working properly
                    thank you a lot to you and everyone
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      #25
                      Let me get this straight.
                      Bojan you never mention you had a imagePass, you said you had a USB issue.
                      It would help if you can explain your issue a little cleary next time.
                      Gald your up.
                      • teckat
                        • 16083
                        #26
                        Are you a End User (Customer) or a Tech. ??
                        All the information that u were given before hand was for an iR6800 Without a Fiery.
                        Customers & /or Techs need to Read and Understand the Specs & Needs of a Machine before Purchase or Install Set-Up. It prevents Aggravation & Frustration on Site.
                        Good Luck in Future
                        • Nicky
                          #27
                          Canon PCL5e/5c Printer Driver v8.70 in this drivers supported and problems solve it.
                          • teckat
                            • 16083
                            #28
                            U missed it/ poster had a Fiery attached and did not know it
                            • SCREWTAPE
                              East Coast Imaging
                              • 3396
                              #29
                              Wake UP...
                              • Fer
                                • Nov 2009
                                • 267
                                #30
                                my model canon IR6800C dadf -m1 no:1000006924 canot connect for usb port.that driver is download and install for my canon ir6800c windows xp 32bit sp3.please send me link to download compatible driver for my model and name driver ?
                                UFR_v1.51_Setup.exe not work for canon site.
                                Tell me step by step how to instal corect driver in USB port not UTP.
                                thanks
                                He did mention an M1, Together with Teckats info about the IR6800C, without N
